LG G7 ThinQ Speaker System Replacement
  1. LG G7 ThinQ Speaker System Replacement, SIM Card: step 1, image 1 of 1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
    Ask FixBot
  2. LG G7 ThinQ Speaker System Replacement, Back Cover: step 2, image 1 of 1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
    Ask FixBot
  3. LG G7 ThinQ Speaker System Replacement, Speaker System: step 3, image 1 of 1
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
    Ask FixBot
  4. LG G7 ThinQ Speaker System Replacement, Remove the speaker system: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use your fingers or tweezers to remove the speaker system.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 55
All Time: 1,306
