LG G7 ThinQ Motherboard Replacement
    1. LG G7 ThinQ Motherboard Replacement, SIM Card: step 1, image 1 of 1
      • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
      • After the SIM card tray is ejected, remove the SIM card tray from the phone.
      • Remove the SIM card from the tray.
      Ask FixBot
    1. LG G7 ThinQ Motherboard Replacement, Back Cover: step 2, image 1 of 1
      • Place the phone so the back cover is facing upwards.
      • Insert the opening picks one by one onto each side with equal pressure.
      • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
      • If the picks are too thick to fit in, you can use the Jimmy to start the process.
      • Use the pick with the best leverage to pry the back cover away from the phone.
      Ask FixBot
    1. LG G7 ThinQ Motherboard Replacement, Speaker System: step 3, image 1 of 1
      • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
      • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
      Ask FixBot
    2. LG G7 ThinQ Motherboard Replacement, Remove the speaker system: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use your fingers or tweezers to remove the speaker system.
      Ask FixBot
    1. LG G7 ThinQ Motherboard Replacement, Motherboard: step 5, image 1 of 1
      Buy
      • Make sure the motherboard is fully disconnected from the battery.
      • Use your fingers or tweezers to remove the motherboard.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 72
All Time: 3,334
