Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Parts
×2Tesa 61395 Double-Sided Tape4.9
Thin, high-bond tape is required if the replacement part does not come with adhesive.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to replace the USB-C port on your LG G6.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Tool used on this step:Plastic Cards$2.99
When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
Tool used on this step:Tweezers$4.99
Locate the sim card tray release mechanism on the right edge.
Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
8 other people completed this guide.
2 Guide Comments
what size tape did you use?
