Up to 20% off select tools
LG G6 Motherboard Replacement
Views: 8.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
36
All Time:
8,254
Comments: 92
88 comments on steps, 4 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Parts
  • ×2
    Tesa 61395 Double-Sided Tape
    4.9
    Thin, high-bond tape is required if the replacement part does not come with adhesive.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard on your LG G6.
    1. LG G6 Motherboard Replacement, iOpener Heating: step 1, image 1 of 2 LG G6 Motherboard Replacement, iOpener Heating: step 1, image 2 of 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Ask FixBot
    2. LG G6 Motherboard Replacement: step 2, image 1 of 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100ËšC (212ËšF).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Ask FixBot
    3. LG G6 Motherboard Replacement: step 3, image 1 of 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Ask FixBot
    4. LG G6 Motherboard Replacement, Alternate iOpener heating method: step 4, image 1 of 2 LG G6 Motherboard Replacement, Alternate iOpener heating method: step 4, image 2 of 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Ask FixBot
    1. LG G6 Motherboard Replacement, Battery: step 5, image 1 of 1
      • Apply the heated iOpener to the edge of the phone for about 2 minutes.
      Ask FixBot
    2. LG G6 Motherboard Replacement: step 6, image 1 of 3 LG G6 Motherboard Replacement: step 6, image 2 of 3 LG G6 Motherboard Replacement: step 6, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
      • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
      • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
      Ask FixBot
    3. LG G6 Motherboard Replacement: step 7, image 1 of 2 LG G6 Motherboard Replacement: step 7, image 2 of 2
      • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
      Ask FixBot
    4. LG G6 Motherboard Replacement: step 8, image 1 of 2 LG G6 Motherboard Replacement: step 8, image 2 of 2
      • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
      Ask FixBot
    5. LG G6 Motherboard Replacement: step 9, image 1 of 1
      • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
      Ask FixBot
    6. LG G6 Motherboard Replacement: step 10, image 1 of 3 LG G6 Motherboard Replacement: step 10, image 2 of 3 LG G6 Motherboard Replacement: step 10, image 3 of 3
      • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
      • Do not use a knife as you may pierce the battery.
      Ask FixBot
    1. LG G6 Motherboard Replacement, Motherboard: step 11, image 1 of 2 LG G6 Motherboard Replacement, Motherboard: step 11, image 2 of 2
      Buy
      • Locate the sim card tray release mechanism on the right edge.
      • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
      Ask FixBot
    2. LG G6 Motherboard Replacement: step 12, image 1 of 3 LG G6 Motherboard Replacement: step 12, image 2 of 3 LG G6 Motherboard Replacement: step 12, image 3 of 3
      • Gently pry off the two connectors at the bottom of the phone.
      • Pry off the tape covering the vibrator.
      Ask FixBot
    3. LG G6 Motherboard Replacement: step 13, image 1 of 2 LG G6 Motherboard Replacement: step 13, image 2 of 2
      • The motherboard is now removable by gently lifting.
      • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
      Ask FixBot
4 other people completed this guide.
Author
with
David Pugliese
1,156 Reputation
4 Guides authored
USF Tampa, Team S2-G6, Passmore Fall 2017 Member of USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 Members
60 Guides authored
4 Guide Comments
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - Reply Share
i found one on ebay
Greg - Reply Share
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - Reply Share
very good detail
Greg - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 8,254
