LG G6 Charge Port Replacement
    1. LG G6 Charge Port Replacement, iOpener Heating: step 1, image 1 of 2 LG G6 Charge Port Replacement, iOpener Heating: step 1, image 2 of 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Ask FixBot
    2. LG G6 Charge Port Replacement: step 2, image 1 of 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Ask FixBot
    3. LG G6 Charge Port Replacement: step 3, image 1 of 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Ask FixBot
    4. LG G6 Charge Port Replacement, Alternate iOpener heating method: step 4, image 1 of 2 LG G6 Charge Port Replacement, Alternate iOpener heating method: step 4, image 2 of 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Ask FixBot
    1. LG G6 Charge Port Replacement, Fingerprint Sensor: step 5, image 1 of 1
      • Apply a heated iOpener to a long edge of the phone for about 2 minutes.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      Ask FixBot
    2. LG G6 Charge Port Replacement: step 6, image 1 of 2 LG G6 Charge Port Replacement: step 6, image 2 of 2
      • In the following steps you will be cutting through the adhesive on the rear glass panel.
      • Take note of the following areas:
      • In addition to cutting around the edge, there is extra adhesive here that should be cut.
      • Avoid sticking the spudger blade in too far here, to avoid damaging the rear button ribbon cable and chip.
      Ask FixBot
    3. LG G6 Charge Port Replacement: step 7, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
      • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
      • Lift on the suction cup, and insert a halberd spudger or opening pick under the rear glass.
      Ask FixBot
    4. LG G6 Charge Port Replacement: step 8, image 1 of 1
      • Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
      Ask FixBot
    5. LG G6 Charge Port Replacement: step 9, image 1 of 2 LG G6 Charge Port Replacement: step 9, image 2 of 2
      • Slide the blade of a Halberd spudger along the side of the phone, separating the adhesive.
      Ask FixBot
    6. LG G6 Charge Port Replacement: step 10, image 1 of 3 LG G6 Charge Port Replacement: step 10, image 2 of 3 LG G6 Charge Port Replacement: step 10, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      Ask FixBot
    7. LG G6 Charge Port Replacement: step 11, image 1 of 2 LG G6 Charge Port Replacement: step 11, image 2 of 2
      • Use the opening picks to slice through any remaining adhesive and open the phone.
      • Remove the glass from the phone.
      • During reassembly, apply new adhesive or high-bond tape if your replacement rear glass does not come with any.
      Ask FixBot
    8. LG G6 Charge Port Replacement: step 12, image 1 of 3 LG G6 Charge Port Replacement: step 12, image 2 of 3 LG G6 Charge Port Replacement: step 12, image 3 of 3
      • Slide the blade of a halberd spudger into the opening on the edge of the rear button bracket.
      • Careful not to push directly against the rear button ribbon cable, to avoid damaging it.
      • Do not push the spudger in too far, to avoid damaging the rear button.
      • Continue sliding the spudger blade around the bracket to cut all the adhesive holding the bracket to the rear case.
      • Remove the bracket.
      Ask FixBot
    9. LG G6 Charge Port Replacement: step 13, image 1 of 3 LG G6 Charge Port Replacement: step 13, image 2 of 3 LG G6 Charge Port Replacement: step 13, image 3 of 3
      • Slide an opening pick between the rear button membrane and the rear case.
      • Slide the pick around the edge of the membrane to separate it from the rear case.
      • This might take some force, as the adhesive holding the membrane to the case is tenacious. Pry slowly, to avoid puncturing or stretching the membrane.
      Ask FixBot
    10. LG G6 Charge Port Replacement: step 14, image 1 of 1
      • Use the blade of a halberd spudger to pry the rear button chip off of the rear case.
      Ask FixBot
    11. LG G6 Charge Port Replacement: step 15, image 1 of 3 LG G6 Charge Port Replacement: step 15, image 2 of 3 LG G6 Charge Port Replacement: step 15, image 3 of 3
      • Use an opening pick to pry the contact pad off of the rear case.
      • Remove the rear button assembly.
      Ask FixBot
    1. LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: step 16, image 1 of 3 LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: step 16, image 2 of 3 LG G6 Charge Port Replacement, Charging Coil and Loudspeaker Assembly: step 16, image 3 of 3
      • Separate the rear glass from the phone,
      • Remove eleven Philips #00 screws.
      Ask FixBot
    2. LG G6 Charge Port Replacement, Remove Charging Coil: step 17, image 1 of 2 LG G6 Charge Port Replacement, Remove Charging Coil: step 17, image 2 of 2
      • Use a spudger to remove the charging coil from the top left corner,
      Ask FixBot
    3. LG G6 Charge Port Replacement, Remove Loudspeaker Assembly: step 18, image 1 of 1
      • Remove loudspeaker assembly.
      Ask FixBot
    4. LG G6 Charge Port Replacement, Battery: step 19, image 1 of 1
      • Use the flat end of a spudger to disconnect the battery connector.
      Ask FixBot
    5. LG G6 Charge Port Replacement, Motherboard: step 20, image 1 of 1
      • Use the flat end of a spudger to disconnect the LCD/Digitizer flex cable.
      • Use the flat end of a spudger to disconnect the charge port flex cable.
      Ask FixBot
    6. LG G6 Charge Port Replacement: step 21, image 1 of 1
      • Use the flat end of a spudger to disconnect the front camera.
      Ask FixBot
    7. LG G6 Charge Port Replacement, SIM Card Tray: step 22, image 1 of 1
      • Insert a SIM card opening tool into the small hole on the left side of the phone and remove the SIM card tray.
      Ask FixBot
    8. LG G6 Charge Port Replacement: step 23, image 1 of 3 LG G6 Charge Port Replacement: step 23, image 2 of 3 LG G6 Charge Port Replacement: step 23, image 3 of 3
      • Lift the motherboard out of the phone.
      • Be careful not to snag any of the connectors on the board.
      Ask FixBot
    9. LG G6 Charge Port Replacement, Charge Port: step 24, image 1 of 3 LG G6 Charge Port Replacement, Charge Port: step 24, image 2 of 3 LG G6 Charge Port Replacement, Charge Port: step 24, image 3 of 3
      • Use the flat end of a spudger to remove the adhesive securing the USB-C charge port to the frame.
      Ask FixBot
13 other people completed this guide.
Kevin Stuckey
1,217 Reputation
2 Guides authored
Anchor Technology Solutions Member of Anchor Technology Solutions
Business
1 Member
24 Guides authored
6 Guide Comments
Excellent AAAAAAAAA ++++
Jose G Ramirez - Reply Share
Awesome tutorial, I skipped the from step 11 to 15. No need to remove the button assembly. Just skipped that and reused the back glass panel with no problems. Thank you!
Ben Fischer - Reply Share
Thanks for your input. It has been a while!
Were you able to replace the port or the port assembly?
FrancisF - Reply Share
I can’t get the back off. I’ve tried so hard but it wont come off. I pulled so &&^&^$^ hard i cracked the back but couldnt get the &&^&^$^ back off wtf
Pengo The Penguino - Reply Share
Hi , I have replaced the port but usb comm still not working. QC3 not working because it also works with working usb comm. I have tried many original cords and chargers.
malikzee111 - Reply Share
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 139
All Time: 19,980
