Up to 20% off select tools
LG G5 Front Panel Assembly
Views: 11K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
98
All Time:
11,062
Comments: 10
6 comments on steps, 4 guide comments.
Go to guide comments
Completed: 32
32 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove your LG G5's front panel assembly. This involves separating the screen from the body of the phone. If you are trying to replace any components within the LG G5, you'll need to follow this guide first!
    1. LG G5 Front Panel Assembly, Front Panel Assembly: step 1, image 1 of 2 LG G5 Front Panel Assembly, Front Panel Assembly: step 1, image 2 of 2
      • While holding the battery release button, pull the bottom end of the phone out of the body.
      Ask FixBot
    2. LG G5 Front Panel Assembly: step 2, image 1 of 3 LG G5 Front Panel Assembly: step 2, image 2 of 3 LG G5 Front Panel Assembly: step 2, image 3 of 3
      • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
      • Press inward with some force to eject the tray.
      • Pull the sim card tray out of the phone.
      Ask FixBot
    3. LG G5 Front Panel Assembly: step 3, image 1 of 2 LG G5 Front Panel Assembly: step 3, image 2 of 2
      • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
      Ask FixBot
    4. LG G5 Front Panel Assembly: step 4, image 1 of 1
      • Insert the plastic opening tool into the seam between the glass screen and the metal body.
      • Pry the glass from the body only a slight amount.
      Ask FixBot
    5. LG G5 Front Panel Assembly: step 5, image 1 of 2 LG G5 Front Panel Assembly: step 5, image 2 of 2
      • Insert the Spudger into the now open space between the body and screen.
      • Push inward to separate the screen even more.
      • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
      • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
      Ask FixBot
    6. LG G5 Front Panel Assembly: step 6, image 1 of 2 LG G5 Front Panel Assembly: step 6, image 2 of 2
      • Peel the screen away from the body. The two parts should be completely separated.
      Ask FixBot
Now you can access all the inner components of the phone!
32 other people completed this guide.
Author
with
Joshua Zalmanowitz
1,847 Reputation
4 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
72 Guides authored
4 Guide Comments
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - Reply Share
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - Reply Share
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - Reply Share
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 98
All Time: 11,062
