LG G5 Charging Port Replacement
    1. LG G5 Charging Port Replacement, Battery: step 1, image 1 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 2 of 3 LG G5 Charging Port Replacement, Battery: step 1, image 3 of 3
      • Power down the phone by holding the power button for several seconds.
      • While holding the battery release button, pull the bottom end of the phone out of the body.
      Ask FixBot
    2. LG G5 Charging Port Replacement: step 2, image 1 of 2 LG G5 Charging Port Replacement: step 2, image 2 of 2
      • Separate the battery from bottom half.
      • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
      Ask FixBot
    1. LG G5 Charging Port Replacement, Charging Port: step 3, image 1 of 2 LG G5 Charging Port Replacement, Charging Port: step 3, image 2 of 2
      • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
      Ask FixBot
    2. LG G5 Charging Port Replacement: step 4, image 1 of 2 LG G5 Charging Port Replacement: step 4, image 2 of 2
      • Insert the plastic opening tool into the bottom seam
      • Pry the plastic from the base only a slight amount.
      Ask FixBot
    3. LG G5 Charging Port Replacement: step 5, image 1 of 2 LG G5 Charging Port Replacement: step 5, image 2 of 2
      • Remove the one 5.5mm Phillips #000 screw.
      Ask FixBot
    4. LG G5 Charging Port Replacement: step 6, image 1 of 3 LG G5 Charging Port Replacement: step 6, image 2 of 3 LG G5 Charging Port Replacement: step 6, image 3 of 3
      • Insert the plastic opening tool into the seam between the two plastic layers.
      • Pry the plastic from the body.
      Ask FixBot
    5. LG G5 Charging Port Replacement: step 7, image 1 of 2 LG G5 Charging Port Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool into the seam under the metal charging port.
      • Pry the metal charging port from the body.
      Ask FixBot
24 other people completed this guide.
Joshua Zalmanowitz
1,817 Reputation
4 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
72 Guides authored
13 Guide Comments
I would love steps to show not only pulling out the usb port, but also putting the new one in and re-assembly. Also maybe tips about things to avoid doing -- easy slip ups people make when doing it. Why replace just the usb port instead of the whole board assembly or instead of the entire bottom module? Thanks! Great pics
jessicacollins267 - Reply Share
Anyone know how to bypass the "insert a supported module" error that comes up after changing the charging port?
Rene - Reply Share
Do you solve the problem? Can you help me, please?
Budai Daniel - Reply Share
I need to do this repair on my phone, but Rene's comment worries me. Does this error message come up often? Can it be fixed?
Brad - Reply Share
Hello. I have the same problem like Rene . I changed the usb port and when I try to power on my smartphone it shows me the picture that said “insert a supported module” like what Rene said earlier. Please, I need help.
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 130
All Time: 25,338
