Up to 20% off select tools
LG G5 Camera Sensor Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
98
All Time:
5,587
Comments: 15
14 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
In this guide, you will be removing the rear camera sensor. Use this guide if you find the rear camera has trouble focusing.
    1. LG G5 Camera Sensor Replacement, Front Panel Assembly: step 1, image 1 of 2 LG G5 Camera Sensor Replacement, Front Panel Assembly: step 1, image 2 of 2
      • While holding the battery release button, pull the bottom end of the phone out of the body.
      Ask FixBot
    2. LG G5 Camera Sensor Replacement: step 2, image 1 of 3 LG G5 Camera Sensor Replacement: step 2, image 2 of 3 LG G5 Camera Sensor Replacement: step 2, image 3 of 3
      • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
      • Press inward with some force to eject the tray.
      • Pull the sim card tray out of the phone.
      Ask FixBot
    3. LG G5 Camera Sensor Replacement: step 3, image 1 of 2 LG G5 Camera Sensor Replacement: step 3, image 2 of 2
      • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
      Ask FixBot
    4. LG G5 Camera Sensor Replacement: step 4, image 1 of 1
      • Insert the plastic opening tool into the seam between the glass screen and the metal body.
      • Pry the glass from the body only a slight amount.
      Ask FixBot
    5. LG G5 Camera Sensor Replacement: step 5, image 1 of 2 LG G5 Camera Sensor Replacement: step 5, image 2 of 2
      • Insert the Spudger into the now open space between the body and screen.
      • Push inward to separate the screen even more.
      • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
      • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
      Ask FixBot
    6. LG G5 Camera Sensor Replacement: step 6, image 1 of 2 LG G5 Camera Sensor Replacement: step 6, image 2 of 2
      • Peel the screen away from the body. The two parts should be completely separated.
      Ask FixBot
    1. LG G5 Camera Sensor Replacement, Screen: step 7, image 1 of 2 LG G5 Camera Sensor Replacement, Screen: step 7, image 2 of 2
      • Once the screen has been separated from the back of the phone, now you can remove the motherboard.
      • Using the #00 Philips head, remove the six 2.7mm Phillips screws.
      Ask FixBot
    2. LG G5 Camera Sensor Replacement: step 8, image 1 of 2 LG G5 Camera Sensor Replacement: step 8, image 2 of 2
      • Insert the plastic opening tool between the screen-ribbon-connector and the motherboard, then pull up. It should pop out easily.
      Ask FixBot
    3. LG G5 Camera Sensor Replacement: step 9, image 1 of 1
      • Separate the motherboard of the phone from the screen of the phone
      Ask FixBot
    4. LG G5 Camera Sensor Replacement: step 10, image 1 of 2 LG G5 Camera Sensor Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
      • The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
      • Be careful with the adhesive that's connected to it. It's easy to pull out.
      Ask FixBot
    5. LG G5 Camera Sensor Replacement: step 11, image 1 of 1
      • Also remove the earpiece casing from the old screen by popping it out with a pair of tweezers.
      • On the new screen, place the casing down first and making sure that it's locked in place. Then place the earpiece on top of it. Gently push it down with your finger until it's secure.
      Ask FixBot
    1. LG G5 Camera Sensor Replacement, Camera Sensor: step 12, image 1 of 3 LG G5 Camera Sensor Replacement, Camera Sensor: step 12, image 2 of 3 LG G5 Camera Sensor Replacement, Camera Sensor: step 12, image 3 of 3
      • Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
      Ask FixBot
6 other people completed this guide.
Author
with
Parker Reynolds
937 Reputation
2 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
72 Guides authored
1 Guide Comment
Is that the camera sensor that has been removed or the wide angle camera?
Thomas Charnley - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 98
All Time: 5,587
