Up to 20% off select tools
LG G5 Battery Replacement
Views: 18K
View statistics:
Past 24 Hours:
8
Past 7 Days:
32
Past 30 Days:
194
All Time:
18,395
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Parts
Introduction
Go to step 1 ↓
This guide will help you through the steps to replace your LG G5 battery. The LG G5 is built to allow simple battery replacement, so you'll only need your hands for this process! Use this guide if your battery will not hold charge.
If your battery is swollen, take appropriate precautions.
    1. LG G5 Battery Replacement, Battery: step 1, image 1 of 3 LG G5 Battery Replacement, Battery: step 1, image 2 of 3 LG G5 Battery Replacement, Battery: step 1, image 3 of 3
      • Power down the phone by holding the power button for several seconds.
      • While holding the battery release button, pull the bottom end of the phone out of the body.
      Ask FixBot
    2. LG G5 Battery Replacement: step 2, image 1 of 2 LG G5 Battery Replacement: step 2, image 2 of 2
      • Separate the battery from bottom half.
      • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
      Ask FixBot
22 other people completed this guide.
Author
with
Sam Goldheart
478,973 Reputation
538 Guides authored
4 Guide Comments
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Reply Share
Was machen wenn Akku Snap In ab ist?
Ra Ku - Reply Share
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Reply Share
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Reply Share
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 194
All Time: 18,395
