LG G5 Auxiliary Port Replacement
    1. LG G5 Auxiliary Port Replacement, Front Panel Assembly: step 1, image 1 of 2 LG G5 Auxiliary Port Replacement, Front Panel Assembly: step 1, image 2 of 2
      • While holding the battery release button, pull the bottom end of the phone out of the body.
      Ask FixBot
    2. LG G5 Auxiliary Port Replacement: step 2, image 1 of 3 LG G5 Auxiliary Port Replacement: step 2, image 2 of 3 LG G5 Auxiliary Port Replacement: step 2, image 3 of 3
      • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
      • Press inward with some force to eject the tray.
      • Pull the sim card tray out of the phone.
      Ask FixBot
    3. LG G5 Auxiliary Port Replacement: step 3, image 1 of 2 LG G5 Auxiliary Port Replacement: step 3, image 2 of 2
      • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
      Ask FixBot
    4. LG G5 Auxiliary Port Replacement: step 4, image 1 of 1
      • Insert the plastic opening tool into the seam between the glass screen and the metal body.
      • Pry the glass from the body only a slight amount.
      Ask FixBot
    5. LG G5 Auxiliary Port Replacement: step 5, image 1 of 2 LG G5 Auxiliary Port Replacement: step 5, image 2 of 2
      • Insert the Spudger into the now open space between the body and screen.
      • Push inward to separate the screen even more.
      • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
      • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
      Ask FixBot
    6. LG G5 Auxiliary Port Replacement: step 6, image 1 of 2 LG G5 Auxiliary Port Replacement: step 6, image 2 of 2
      • Peel the screen away from the body. The two parts should be completely separated.
      Ask FixBot
    1. LG G5 Auxiliary Port Replacement, Auxiliary Port: step 7, image 1 of 1
      • Locate the auxiliary port on the top right of the phone
      • Using a finger, carefully take the port out
      • Replace the old auxiliary port with a new one by orienting the hole towards the top of the phone and the gold ribbon to the left (as shown in the picture).
      Ask FixBot
8 other people completed this guide.
Joshua Zalmanowitz
1,817 Reputation
4 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
72 Guides authored
3 Guide Comments
I saw a video where someone used a guitar pick as the plastic opening tool, seems safer to me. And that person also had a great idea to shove a pencil in the battery bay to apply a separating force, so that as you work the seam with a guitar pick, the the two halves will naturally want to separate.
Adam Mizban - Reply Share
Hi, I have two LG G5 phone. Let's call them
A & B.
So , B overheats and the battery last less than an hour. So I took the battery from A and I put it in B and I put the B battery in the A. Results: B still overheats and not the A ??? I also left the connector blocks on the batteries when I did the switching. So what could be the cause of this?
Julie Desruisseaux - Reply Share
weak signal problem
Bilal Khan - Reply Share
Past 24 Hours: 9
Past 7 Days: 26
Past 30 Days: 120
All Time: 6,273
