LG G4 Speaker Replacement
    1. LG G4 Speaker Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off.
      • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
      Ask FixBot
    2. LG G4 Speaker Replacement: step 2, image 1 of 2 LG G4 Speaker Replacement: step 2, image 2 of 2
      • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
      Ask FixBot
    3. LG G4 Speaker Replacement: step 3, image 1 of 3 LG G4 Speaker Replacement: step 3, image 2 of 3 LG G4 Speaker Replacement: step 3, image 3 of 3
      • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
      Ask FixBot
    4. LG G4 Speaker Replacement: step 4, image 1 of 3 LG G4 Speaker Replacement: step 4, image 2 of 3 LG G4 Speaker Replacement: step 4, image 3 of 3
      • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
      • Detach the cover with your fingers
      Ask FixBot
    1. LG G4 Speaker Replacement, Speaker: step 5, image 1 of 2 LG G4 Speaker Replacement, Speaker: step 5, image 2 of 2
      • Detach the bottom portion of the plastic panel you just removed by wedging the plastic opening tool under the top part of the clip, and sliding the bottom portion of the panel downward away from the top portion.
      • The bottom portion of the plastic panel contains the speaker to be replaced, all as one part.
      Ask FixBot
8 other people completed this guide.
carolinavind
2,735 Reputation
3 Guides authored
USF Tampa, Team 16-5, Wollert Fall 2015 Member of USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 93
All Time: 7,612
