Up to 20% off select tools
LG G4 Screen Assembly Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
81
All Time:
2,422
Comments: 7
7 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Learn how to replace the full screen assembly, including the LCD, digitizer, and display frame.
This guide does not cover removing the fused glass display and digitizer from the display frame, so if your part is missing the supporting frame, follow the more complicated LCD Digitizer replacement guide instead.
    1. LG G4 Screen Assembly Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off.
      • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
      Ask FixBot
    2. LG G4 Screen Assembly Replacement: step 2, image 1 of 2 LG G4 Screen Assembly Replacement: step 2, image 2 of 2
      • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
      Ask FixBot
    3. LG G4 Screen Assembly Replacement: step 3, image 1 of 3 LG G4 Screen Assembly Replacement: step 3, image 2 of 3 LG G4 Screen Assembly Replacement: step 3, image 3 of 3
      • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
      Ask FixBot
    4. LG G4 Screen Assembly Replacement: step 4, image 1 of 3 LG G4 Screen Assembly Replacement: step 4, image 2 of 3 LG G4 Screen Assembly Replacement: step 4, image 3 of 3
      • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
      • Detach the cover with your fingers
      Ask FixBot
    1. LG G4 Screen Assembly Replacement, Motherboard: step 5, image 1 of 2 LG G4 Screen Assembly Replacement, Motherboard: step 5, image 2 of 2
      • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
      • Front-facing camera connector.
      • Rear-facing camera connector.
      • Digitizer connector.
      • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
      Ask FixBot
    2. LG G4 Screen Assembly Replacement: step 6, image 1 of 2 LG G4 Screen Assembly Replacement: step 6, image 2 of 2
      • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
      Ask FixBot
    1. LG G4 Screen Assembly Replacement, Screen Assembly: step 7, image 1 of 1
      • Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
      Ask FixBot
    2. LG G4 Screen Assembly Replacement: step 8, image 1 of 2 LG G4 Screen Assembly Replacement: step 8, image 2 of 2
      Tool used on this step:
      Spudger
      $2.99
      Buy
      • Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
      Ask FixBot
    3. LG G4 Screen Assembly Replacement, Other components: step 9, image 1 of 1
      • You may also need to remove the vibration motor (the small circular component with two gold contacts), ear-speaker, and two rubber covers on either side of the ear-speaker to transfer these over to the new display assembly.
      • Use a spudger to carefully remove these components and then place them in the new display assembly..
      Ask FixBot
4 other people completed this guide.
Author
with
Sam Goldheart
478,973 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 81
All Time: 2,422
