Up to 20% off select tools
LG G4 Motherboard Replacement
Views: 72K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
127
All Time:
72,228
Comments: 31
6 comments on steps, 25 guide comments.
Go to guide comments
Completed: 56
56 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Parts
  • LG G4 Motherboard
    View
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the Motherboard.
    1. LG G4 Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off.
      • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
      Ask FixBot
    2. LG G4 Motherboard Replacement: step 2, image 1 of 2 LG G4 Motherboard Replacement: step 2, image 2 of 2
      • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
      Ask FixBot
    3. LG G4 Motherboard Replacement: step 3, image 1 of 3 LG G4 Motherboard Replacement: step 3, image 2 of 3 LG G4 Motherboard Replacement: step 3, image 3 of 3
      • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
      Ask FixBot
    4. LG G4 Motherboard Replacement: step 4, image 1 of 3 LG G4 Motherboard Replacement: step 4, image 2 of 3 LG G4 Motherboard Replacement: step 4, image 3 of 3
      • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
      • Detach the cover with your fingers
      Ask FixBot
    1. LG G4 Motherboard Replacement, Motherboard: step 5, image 1 of 2 LG G4 Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
      • Front-facing camera connector.
      • Rear-facing camera connector.
      • Digitizer connector.
      • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
      Ask FixBot
    2. LG G4 Motherboard Replacement: step 6, image 1 of 2 LG G4 Motherboard Replacement: step 6, image 2 of 2
      • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
      Ask FixBot
56 other people completed this guide.
Author
with
carolinavind
2,735 Reputation
3 Guides authored
USF Tampa, Team 16-5, Wollert Fall 2015 Member of USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Members
84 Guides authored
25 Guide Comments
Where can I get a motherboard? I have been looking everywhere with no luck.
nellyquicksilver - Reply Share
If you had it less then a year lg will send u a replacement but if your phone is damaged they will charge u just say it's not damage and swap the boards and send them the new one back so u won't be charged they won't notice I just did it
Alex - Reply Share
i have to ask did they ever notice with the swap???
mklb492 - Reply Share
If my phone has the boot loop problem and i change the board will mi picture still be there ??
josean ramos - Reply Share
Did you find a resolution to this problem? I am facing the same thing!
Shahad Shihab - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 127
All Time: 72,228
