Up to 20% off select tools
LG G4 Front Camera Replacement
Views: 5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
97
All Time:
5,007
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
    1. LG G4 Front Camera Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the phone is powered off.
      • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
      Ask FixBot
    2. LG G4 Front Camera Replacement: step 2, image 1 of 2 LG G4 Front Camera Replacement: step 2, image 2 of 2
      • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
      Ask FixBot
    3. LG G4 Front Camera Replacement: step 3, image 1 of 3 LG G4 Front Camera Replacement: step 3, image 2 of 3 LG G4 Front Camera Replacement: step 3, image 3 of 3
      • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
      Ask FixBot
    4. LG G4 Front Camera Replacement: step 4, image 1 of 3 LG G4 Front Camera Replacement: step 4, image 2 of 3 LG G4 Front Camera Replacement: step 4, image 3 of 3
      • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
      • Detach the cover with your fingers
      Ask FixBot
    1. LG G4 Front Camera Replacement, Front Camera: step 5, image 1 of 3 LG G4 Front Camera Replacement, Front Camera: step 5, image 2 of 3 LG G4 Front Camera Replacement, Front Camera: step 5, image 3 of 3
      • Detach the Front Camera ribbon cable located on the top right corner of the back of the phone by gently lifting it up with a plastic opening tool. Remove the front camera.
      • Be careful when removing the cables and pulling out the front camera to avoid tearing the attached cable.
      Ask FixBot
5 other people completed this guide.
Author
with
Austin Stratton
1,582 Reputation
4 Guides authored
USF Tampa, Team 16-5, Wollert Fall 2015 Member of USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 97
All Time: 5,007
