LG G3 Vigor Motherboard Replacement
    1. LG G3 Vigor Motherboard Replacement, Rear Case: step 1, image 1 of 1
      • Locate the notch on the bottom right of the phone.
      Ask FixBot
    2. LG G3 Vigor Motherboard Replacement: step 2, image 1 of 1
      • Gently pull the cover on the back of the phone off to locate the battery.
      Ask FixBot
    1. LG G3 Vigor Motherboard Replacement, Battery: step 3, image 1 of 1
      • Remove the battery by lifting from the slot at the bottom of the battery.
      Ask FixBot
    1. LG G3 Vigor Motherboard Replacement, Midframe: step 4, image 1 of 1
      • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
      Ask FixBot
    2. LG G3 Vigor Motherboard Replacement: step 5, image 1 of 3 LG G3 Vigor Motherboard Replacement: step 5, image 2 of 3 LG G3 Vigor Motherboard Replacement: step 5, image 3 of 3
      • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
      Ask FixBot
    1. LG G3 Vigor Motherboard Replacement, Rear Facing Camera: step 6, image 1 of 1
      • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
      Ask FixBot
    1. LG G3 Vigor Motherboard Replacement, Front Facing Camera: step 7, image 1 of 2 LG G3 Vigor Motherboard Replacement, Front Facing Camera: step 7, image 2 of 2
      • Remove the front camera.
      Ask FixBot
    1. LG G3 Vigor Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
      Ask FixBot
    2. LG G3 Vigor Motherboard Replacement: step 9, image 1 of 2 LG G3 Vigor Motherboard Replacement: step 9, image 2 of 2
      • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
      • The motherboard should now be able to be lifted out of the device.
      Ask FixBot
8 other people completed this guide.
Jared Stickl
407 Reputation
1 Guide authored
USF Tampa, Team 12-5, Eyestone Spring 2016 Member of USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 98
All Time: 2,356
