Up to 20% off select tools
LG G3 Vigor Display Assembly Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
92
All Time:
2,848
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the display assembly on your LG G3 Vigor.
    1. LG G3 Vigor Display Assembly Replacement, Rear Case: step 1, image 1 of 1
      • Locate the notch on the bottom right of the phone.
      Ask FixBot
    2. LG G3 Vigor Display Assembly Replacement: step 2, image 1 of 1
      • Gently pull the cover on the back of the phone off to locate the battery.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Battery: step 3, image 1 of 1
      • Remove the battery by lifting from the slot at the bottom of the battery.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Midframe: step 4, image 1 of 1
      • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
      Ask FixBot
    2. LG G3 Vigor Display Assembly Replacement: step 5, image 1 of 3 LG G3 Vigor Display Assembly Replacement: step 5, image 2 of 3 LG G3 Vigor Display Assembly Replacement: step 5, image 3 of 3
      • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: step 6, image 1 of 1
      • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: step 7, image 1 of 2 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: step 7, image 2 of 2
      • Remove the front camera.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Motherboard: step 8, image 1 of 1
      • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
      Ask FixBot
    2. LG G3 Vigor Display Assembly Replacement: step 9, image 1 of 2 LG G3 Vigor Display Assembly Replacement: step 9, image 2 of 2
      • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
      • The motherboard should now be able to be lifted out of the device.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Vibration Motor: step 10, image 1 of 1
      • Use a spudger to remove the vibration motor.
      • It may have some slight adhesive, so some force may be necessary.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: step 11, image 1 of 1
      • Remove the earpiece speaker with the metal spudger by prying it out.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Headphone Jack: step 12, image 1 of 1
      • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
      Ask FixBot
    1. LG G3 Vigor Display Assembly Replacement, Display Assembly: step 13, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
      Ask FixBot
    2. LG G3 Vigor Display Assembly Replacement: step 14, image 1 of 1
      • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
      • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
      • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
      Ask FixBot
    3. LG G3 Vigor Display Assembly Replacement: step 15, image 1 of 1
      • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
      Ask FixBot
6 other people completed this guide.
Author
with
Zhong Zhen
675 Reputation
3 Guides authored
USF Tampa, Team 12-5, Eyestone Spring 2016 Member of USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 Members
60 Guides authored
2 Guide Comments
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - Reply Share
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 92
All Time: 2,848
