LG G3 LCD and Digitizer Replacement
    1. LG G3 LCD and Digitizer Replacement, Back Cover: step 1, image 1 of 2 LG G3 LCD and Digitizer Replacement, Back Cover: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
      • Pry the back cover up to separate its plastic clips.
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 2, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 2, image 2 of 2
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
      • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Ask FixBot
    1. LG G3 LCD and Digitizer Replacement, Battery: step 3, image 1 of 2 LG G3 LCD and Digitizer Replacement, Battery: step 3, image 2 of 2
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 4, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 4, image 2 of 2
      • Lift the battery out of its recess and remove it.
      Ask FixBot
    1. LG G3 LCD and Digitizer Replacement, Loudspeaker: step 5, image 1 of 1
      • Remove the four Phillips #00 screws (4 mm length).
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 6, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 6, image 2 of 2
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
      • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
      Ask FixBot
    3. LG G3 LCD and Digitizer Replacement: step 7, image 1 of 3 LG G3 LCD and Digitizer Replacement: step 7, image 2 of 3 LG G3 LCD and Digitizer Replacement: step 7, image 3 of 3
      • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
      Ask FixBot
    1. LG G3 LCD and Digitizer Replacement, Motherboard Cover Assembly: step 8, image 1 of 1
      • Remove the eight Phillips #00 screws (4 mm length).
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 9, image 1 of 3 LG G3 LCD and Digitizer Replacement: step 9, image 2 of 3 LG G3 LCD and Digitizer Replacement: step 9, image 3 of 3
      • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
      • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
      • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
      • Work your way along the right edge.
      Ask FixBot
    3. LG G3 LCD and Digitizer Replacement: step 10, image 1 of 3 LG G3 LCD and Digitizer Replacement: step 10, image 2 of 3 LG G3 LCD and Digitizer Replacement: step 10, image 3 of 3
      • Carefully lift the right edge of the motherboard cover.
      • The remaining plastic clips should open during this process or can be unhinged easily by hand.
      • Remove the motherboard assembly.
      Ask FixBot
    1. LG G3 LCD and Digitizer Replacement, Motherboard: step 11, image 1 of 2 LG G3 LCD and Digitizer Replacement, Motherboard: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the display flex cable.
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 12, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 12, image 2 of 2
      • Use a spudger to pry up and disconnect the digitizer flex cable.
      Ask FixBot
    3. LG G3 LCD and Digitizer Replacement: step 13, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the rear camera flex cable.
      Ask FixBot
    4. LG G3 LCD and Digitizer Replacement: step 14, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 14, image 2 of 2
      • Use a spudger to pry up and disconnect the front camera flex cable.
      Ask FixBot
    5. LG G3 LCD and Digitizer Replacement: step 15, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 15, image 2 of 2
      • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
      • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
      Ask FixBot
    6. LG G3 LCD and Digitizer Replacement: step 16, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 16, image 2 of 2
      • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
      Ask FixBot
    7. LG G3 LCD and Digitizer Replacement: step 17, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 17, image 2 of 2
      • Grab the top section of the motherboard and carefully lift it out of the phone.
      Ask FixBot
    1. LG G3 LCD and Digitizer Replacement, LCD and Digitizer: step 18, image 1 of 3 LG G3 LCD and Digitizer Replacement, LCD and Digitizer: step 18, image 2 of 3 LG G3 LCD and Digitizer Replacement, LCD and Digitizer: step 18, image 3 of 3
      • Remove the metal tape to reveal the ribbon cables connected to the screen
      • The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
      • Be careful when removing the metal tape. We can reuse it after we replace the screen
      Ask FixBot
    2. LG G3 LCD and Digitizer Replacement: step 19, image 1 of 2 LG G3 LCD and Digitizer Replacement: step 19, image 2 of 2
      • If you wish to preserve the LCD screen for whatever reason, it is recommended you use a heat gun around the sides in order to weaken the adhesive that keeps the screen in place
      • Take something thin, such as a knife, and wedge it between the screen and the body of the phone
      • One you have created some space, wedge your plastic opening tool into the space and remove the knife
      • Move your plastic opening tool up and down the side of the phone while lightly pulling up. Repeat this for all sides until the screen comes out
      • If you wish to preserve the LCD screen, be careful how deep you wedge the plastic opening tool in and how hard you pull up to get the screen out. Depending on the depth of the plastic opening tool and strength used, there is a high risk of damaging the LCD screen
      • Remove the old adhesive from the body and replace with new adhesive so the new screen will stay in place
      Ask FixBot
    3. LG G3 LCD and Digitizer Replacement: step 20, image 1 of 1
      • Before reassembly, be sure to transfer the front speaker grille if it is not included with the new screen. If not, carefully push the grille out from the old screen, then reinsert it on the new LCD.
      Ask FixBot
6 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
1 Guide Comment
I have a working LG G3 screen (44 pin connector) that I'm trying to jumper wire to a LG Zone 4/Aristo 2/Phoenix 4 (Same phone 210) with no screen (40 pin connector). I have the connector pin outs for both but I want to know is this possible to do?? Scenario: I'm on a deserted island and can't buy a replacement screen for my Zone 4. I know it's going to be a long and tedious task but are the voltages even compatible enough to attempt this?
Please contact me at s.e.davis8304@gmail.com or amebrizee@gmail.com if you know anyone who can help me with this information. Thank you.
Stephanie - Reply Share
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 61
All Time: 2,981
