LG G3 Earpiece Replacement
    1. LG G3 Earpiece Replacement, Back Cover: step 1, image 1 of 2 LG G3 Earpiece Replacement, Back Cover: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
      • Pry the back cover up to separate its plastic clips.
      Ask FixBot
    2. LG G3 Earpiece Replacement: step 2, image 1 of 2 LG G3 Earpiece Replacement: step 2, image 2 of 2
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
      • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Ask FixBot
    1. LG G3 Earpiece Replacement, Battery: step 3, image 1 of 2 LG G3 Earpiece Replacement, Battery: step 3, image 2 of 2
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      Ask FixBot
    2. LG G3 Earpiece Replacement: step 4, image 1 of 2 LG G3 Earpiece Replacement: step 4, image 2 of 2
      • Lift the battery out of its recess and remove it.
      Ask FixBot
    1. LG G3 Earpiece Replacement, Loudspeaker: step 5, image 1 of 1
      • Remove the four Phillips #00 screws (4 mm length).
      Ask FixBot
    2. LG G3 Earpiece Replacement: step 6, image 1 of 2 LG G3 Earpiece Replacement: step 6, image 2 of 2
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
      • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
      Ask FixBot
    3. LG G3 Earpiece Replacement: step 7, image 1 of 3 LG G3 Earpiece Replacement: step 7, image 2 of 3 LG G3 Earpiece Replacement: step 7, image 3 of 3
      • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
      Ask FixBot
    1. LG G3 Earpiece Replacement, Motherboard Cover Assembly: step 8, image 1 of 1
      • Remove the eight Phillips #00 screws (4 mm length).
      Ask FixBot
    2. LG G3 Earpiece Replacement: step 9, image 1 of 3 LG G3 Earpiece Replacement: step 9, image 2 of 3 LG G3 Earpiece Replacement: step 9, image 3 of 3
      • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
      • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
      • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
      • Work your way along the right edge.
      Ask FixBot
    3. LG G3 Earpiece Replacement: step 10, image 1 of 3 LG G3 Earpiece Replacement: step 10, image 2 of 3 LG G3 Earpiece Replacement: step 10, image 3 of 3
      • Carefully lift the right edge of the motherboard cover.
      • The remaining plastic clips should open during this process or can be unhinged easily by hand.
      • Remove the motherboard assembly.
      Ask FixBot
    1. LG G3 Earpiece Replacement, Motherboard: step 11, image 1 of 2 LG G3 Earpiece Replacement, Motherboard: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the display flex cable.
      Ask FixBot
    2. LG G3 Earpiece Replacement: step 12, image 1 of 2 LG G3 Earpiece Replacement: step 12, image 2 of 2
      • Use a spudger to pry up and disconnect the digitizer flex cable.
      Ask FixBot
    3. LG G3 Earpiece Replacement: step 13, image 1 of 2 LG G3 Earpiece Replacement: step 13, image 2 of 2
      • Use a spudger to pry up and disconnect the rear camera flex cable.
      Ask FixBot
    4. LG G3 Earpiece Replacement: step 14, image 1 of 2 LG G3 Earpiece Replacement: step 14, image 2 of 2
      • Use a spudger to pry up and disconnect the front camera flex cable.
      Ask FixBot
    5. LG G3 Earpiece Replacement: step 15, image 1 of 2 LG G3 Earpiece Replacement: step 15, image 2 of 2
      • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
      • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
      Ask FixBot
    6. LG G3 Earpiece Replacement: step 16, image 1 of 2 LG G3 Earpiece Replacement: step 16, image 2 of 2
      • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
      Ask FixBot
    7. LG G3 Earpiece Replacement: step 17, image 1 of 2 LG G3 Earpiece Replacement: step 17, image 2 of 2
      • Grab the top section of the motherboard and carefully lift it out of the phone.
      Ask FixBot
    1. LG G3 Earpiece Replacement, Earpiece speaker: step 18, image 1 of 2 LG G3 Earpiece Replacement, Earpiece speaker: step 18, image 2 of 2
      Tool used on this step:
      Buy
      • During removal of the earpiece speaker, remove it together with the foam gasket underneath.
      • Use a pair of tweezers to remove the earpiece speaker.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8 other people completed this guide.
Dominik Schnabelrauch
265,991 Reputation
682 Guides authored
3 Guide Comments
Can't just remove the earpiece without removing the motherboard?
bassamxp - Reply Share
unless you broke the phone, NO
Tarik Kaya - Reply Share
To reassemble the earpiece what kind of adhesive do I need?
DukeCrom - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 101
All Time: 9,536
