Up to 20% off select tools
LG G3 Battery Replacement
Views: 19K
View statistics:
Past 24 Hours:
8
Past 7 Days:
27
Past 30 Days:
148
All Time:
19,255
Comments: 1
1 guide comment.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Very easy
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to remove or to replace a worn-out battery in the LG G3 (B855).
If your battery is swollen, take appropriate precautions.
    1. LG G3 Battery Replacement, Back Cover: step 1, image 1 of 2 LG G3 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
      • Pry the back cover up to separate its plastic clips.
      Ask FixBot
    2. LG G3 Battery Replacement: step 2, image 1 of 2 LG G3 Battery Replacement: step 2, image 2 of 2
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
      • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Ask FixBot
    1. LG G3 Battery Replacement, Battery: step 3, image 1 of 2 LG G3 Battery Replacement, Battery: step 3, image 2 of 2
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      Ask FixBot
    2. LG G3 Battery Replacement: step 4, image 1 of 2 LG G3 Battery Replacement: step 4, image 2 of 2
      • Lift the battery out of its recess and remove it.
      Ask FixBot
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
1 Guide Comment
Thank you very much!
ItayDigital - Reply Share
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 148
All Time: 19,255
