LG G2 mini LTE Front Facing Camera Replacement
    1. LG G2 mini LTE Front Facing Camera Replacement, Remove the Battery Cover: step 1, image 1 of 1
      • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
      • Pry upward and the cover should pop off easily.
      Ask FixBot
    2. LG G2 mini LTE Front Facing Camera Replacement, Remove the Battery: step 2, image 1 of 1
      • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
      Ask FixBot
    3. LG G2 mini LTE Front Facing Camera Replacement, Unscrew the Motherboard Cover: step 3, image 1 of 2 LG G2 mini LTE Front Facing Camera Replacement, Unscrew the Motherboard Cover: step 3, image 2 of 2
      • Locate 10 screws and remove each one using a Philips head screw driver.
      Ask FixBot
    4. LG G2 mini LTE Front Facing Camera Replacement, Remove the Motherboard Cover: step 4, image 1 of 1
      • Use a plastic spudger tool to pry away the cover by placing it between the cover and the phone.
      • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
      Ask FixBot
    5. LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: step 5, image 1 of 3 LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: step 5, image 2 of 3 LG G2 mini LTE Front Facing Camera Replacement, Remove the Front Facing Camera: step 5, image 3 of 3
      • Locate the front facing camera.
      • Pry the ribbon cable off of it's connector using the plastic spudger tool or a flat head screwdriver.
      • Use your finger to remove the camera.
      Ask FixBot
Aung Myin Thu Mayet
653 Reputation
4 Guides authored
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 100
All Time: 1,923
