LG G2 mini LTE Battery Replacement
    1. LG G2 mini LTE Battery Replacement, Removing The Cover: step 1, image 1 of 3 LG G2 mini LTE Battery Replacement, Removing The Cover: step 1, image 2 of 3 LG G2 mini LTE Battery Replacement, Removing The Cover: step 1, image 3 of 3
      • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
      • Pry upward and the cover should pop off easily.
      Ask FixBot
    2. LG G2 mini LTE Battery Replacement, Removing The Battery: step 2, image 1 of 3 LG G2 mini LTE Battery Replacement, Removing The Battery: step 2, image 2 of 3 LG G2 mini LTE Battery Replacement, Removing The Battery: step 2, image 3 of 3
      • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
      • Now you are able to replace the battery with a new one.
      Ask FixBot
2 other people completed this guide.
Aung Myin Thu Mayet
653 Reputation
4 Guides authored
UMass Dartmouth, Team 1-9, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-9, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G9
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 112
All Time: 2,749
