Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Before beginning the process of display assembly replacement, set aside an area for all the screws that will be taken out and set aside as replacing the display assembly is the final part that is left over once all other components have been removed.
Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
Start at the top left of the battery and slide your nylon spudger under the battery. There is a layer of adhesive that keeps the battery in the case. Use steady, firm pressure to pull the battery up.
Removed the cables by pulling them out, they are held in by black tape.
The vibe motor is held in by a strong adhesive, use a slim tool to get underneath and remove.
The camera can be removed effortlessly by using a slim plastic tool to lift it out of the assembly, start under the ribbon cable to pry out.
6 other people completed this guide.
