LG G2 LCD and Digitizer Replacement
    1. LG G2 LCD and Digitizer Replacement, LCD and Digitizer: step 1, image 1 of 2 LG G2 LCD and Digitizer Replacement, LCD and Digitizer: step 1, image 2 of 2
      • Power down your phone.
      • With your screen facing down, look on the right side of the phone for the SIM drawer. Slide your metal opening tool just above the drawer and push upward. Use gentle pressure (never force anything) and make your way around the perimeter of the device. The phone back is just clipped on—no adhesive here!
      Ask FixBot
    2. LG G2 LCD and Digitizer Replacement: step 2, image 1 of 1
      • Remove the eleven Phillips #00 silver screws and one black (circled in yellow) securing the midframe.
      • The screws have different finishes and slightly different shapes. Make sure you organize them so that you can reassemble the phone correctly.
      Ask FixBot
    3. LG G2 LCD and Digitizer Replacement: step 3, image 1 of 3 LG G2 LCD and Digitizer Replacement: step 3, image 2 of 3 LG G2 LCD and Digitizer Replacement: step 3, image 3 of 3
      • The back case of the phone has two separate pieces; we will pry them up now. Slide the spudger under the back case (mind the motherboard under it—keep your clearance as high as possible).
      • Be sure you use gentle upwards pressure. iFixit Jedis know too much pressure results in poor repairs.
      Ask FixBot
    4. LG G2 LCD and Digitizer Replacement: step 4, image 1 of 1
      • Now that the back case has been completely removed, it's time to disconnect all the ribbon cables connected to the two boards.
      Ask FixBot
    5. LG G2 LCD and Digitizer Replacement: step 5, image 1 of 1
      • Disconnect the antennas from both sides of the top and bottom boards.
      • Be EXTREMELY careful separating these from the board! As you can see in the second picture, these aren't held down to the board well. (Even after eight years of fixing phones, even the best Jedi can still exert too much force.)
      Ask FixBot
    6. LG G2 LCD and Digitizer Replacement: step 6, image 1 of 3 LG G2 LCD and Digitizer Replacement: step 6, image 2 of 3 LG G2 LCD and Digitizer Replacement: step 6, image 3 of 3
      • On the bottom-left side of the phone is a little board that goes with this dual-ribbon board contraption. Be sure you give the board a little push with your plastic prying tool—it'll eventually loosen.
      • Gently lift the board from the top with the power button/volume assembly in your fingers, and pry the bottom part of the board free of the phone housing.
      • The cables on the bottom can get caught on the bottom board—just be gentle as you lift it out of the phone.
      • In picture 3 there is a red box around a little plastic piece that comes with this assembly. Remember this tucks UNDER the board once you're putting it back in.
      Ask FixBot
    7. LG G2 LCD and Digitizer Replacement: step 7, image 1 of 2 LG G2 LCD and Digitizer Replacement: step 7, image 2 of 2
      • Make sure all of your ribbon cables are free of the board. Use your plastic prying tool and lift up on the board. If all of the cables are out of the way, it will come free.
      Ask FixBot
    8. LG G2 LCD and Digitizer Replacement: step 8, image 1 of 2 LG G2 LCD and Digitizer Replacement: step 8, image 2 of 2
      • Now you need to get that battery out of there. I used a sturdier metal prying tool to CAREFULLY slide under the battery to free it from the adhesive. An old credit card might work better and pose less risk to the battery.
      • Do not puncture or deform the battery, or it may leak dangerous chemicals or catch fire.
      Ask FixBot
    9. LG G2 LCD and Digitizer Replacement: step 9, image 1 of 1
      • Ready to get hot and steamy? Get out that heat gun baby!
      • Keep your heat gun about 4-6 inches above the screen of the phone and make even passes back and forth over the glass. Keep the heat on it for 1-2 minutes.
      • Now let's get that screen out!
      Ask FixBot
    10. LG G2 LCD and Digitizer Replacement: step 10, image 1 of 3 LG G2 LCD and Digitizer Replacement: step 10, image 2 of 3 LG G2 LCD and Digitizer Replacement: step 10, image 3 of 3
      • Take a thin prying tool and slide it between the glass and the plastic housing of the phone.
      • Go around the perimeter of the phone and lift the glass free. Do not slide your opening tool in too deep while doing this.
      • Don't slice any cables! There's one in the upper-right corner, plus a wide, flat one with two connectors on the bottom, towards the middle of the screen.
      • Carefully pry the ribbon glued down on the inside opposite the screen. Once that is free, slide it and the small connector through the case just to the side of it out to free up the screen to remove.
      • Be sure when replacing the screen to use a good bit of double-sided tape. I had problems with the bottom right corner coming up and had to disassemble and reapply tape.
      Ask FixBot
    11. LG G2 LCD and Digitizer Replacement: step 11, image 1 of 1
      • Problems? When I replaced this screen I couldn't get it to turn on at first. If this happens, hold the volume down and power buttons simultaneously.
      • This will reset the phone and hopefully get it to recognize that new screen.
      • When re-assembling the device, there is a chance your clips will not fit correctly over the volume and power button faceplate. A little force around it should snap them together.
      Ask FixBot
148 other people completed this guide.
Jeremy Thompson
5,653 Reputation
2 Guides authored
62 Guide Comments
Hey i had to replace my screen on my lg g2 before this guide was up wasn't too bad to do, but my phone gets no signal bars anymore. I ordered new antenna wires and replaced them both still no signal bars just a red x most of the time in certain places ill get a bar or 2 but only for a min or so what do you think it could be?
Kevin Burgess - Reply Share
The small board along the bottom of the phone is the actual antenna, you will probably need to replace this. Make sure the screw that holds it down in place is also not stripped, if it does not grab onto the frame correctly then it will not be able to pick up service as easily
nickbrinks - Reply Share
there is another ribbon cable not marked in the step 4 picture. i have a pink square around it here: http://i.imgur.com/AMSuP5A.png
also both boards came out together when i removed them.
Lukyan - Reply Share
Take your time and follow the guide and you'll do fine. Read the guide, look at all the pictures, then carefully re-read each step and look at each picture in each step. There are a couple 'gotcha' boards/cables that you could destroy if you're not watching and being careful. It took me roughly 2.5 hours to do this because I was being extra careful and took some breaks to rest my eyes. Note: You'll need to get a roll of double-side phone tape to go with your new screen to stick it back to the frame.
Andy Stewart - Reply Share
I accidentally ordered screen for D801, but I have D802, I didn't wanted to spend another fortune for the display assembly and I ordered lcd cable for D801 and hope it work's, but it weren't turning on, so I forced right side connector to the motherboard, it lighted up the display, but half of the touch weren't still working, so i tried to reconnect original cable (D802) but it didn't worked or if it did, it lighted up just for a moment, what could be the problem and how could I fix it? please help me.
matiss613 - Reply Share
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 127
All Time: 275,939
