LG G Watch Rear Case Replacement
    1. LG G Watch Rear Case Replacement, Wristband: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
      • Be prepared to apply some pressure with your fingers to perform the following action.
      • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
      • Grasp the exposed shoulder with the tweezers to perform the next step.
      Ask FixBot
    2. LG G Watch Rear Case Replacement: step 2, image 1 of 2 LG G Watch Rear Case Replacement: step 2, image 2 of 2
      • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
      • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
      • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
      • Repeat steps 1 and 2 for the other wristband.
      Ask FixBot
    1. LG G Watch Rear Case Replacement, Rear Case: step 3, image 1 of 1
      • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
      Ask FixBot
    2. LG G Watch Rear Case Replacement: step 4, image 1 of 2 LG G Watch Rear Case Replacement: step 4, image 2 of 2
      • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
      • Gently pull the two halves apart.
      Ask FixBot
2 other people completed this guide.
Geoff Wacker
93,075 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 103
All Time: 1,479
