Up to 20% off select tools
LG G Watch R Power Button
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
111
All Time:
3,537
Comments: 10
10 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Removing the power button might be useful when attempting to clean the device.
    1. LG G Watch R Power Button, Back Case: step 1, image 1 of 2 LG G Watch R Power Button, Back Case: step 1, image 2 of 2
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      Ask FixBot
    2. LG G Watch R Power Button: step 2, image 1 of 1
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      Ask FixBot
    3. LG G Watch R Power Button: step 3, image 1 of 1
      • Remove the back case.
      Ask FixBot
    1. LG G Watch R Power Button, Motherboard: step 4, image 1 of 2 LG G Watch R Power Button, Motherboard: step 4, image 2 of 2
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      Ask FixBot
    2. LG G Watch R Power Button: step 5, image 1 of 2 LG G Watch R Power Button: step 5, image 2 of 2
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      Ask FixBot
    3. LG G Watch R Power Button: step 6, image 1 of 1
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      Ask FixBot
    1. LG G Watch R Power Button, Battery Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      Ask FixBot
    1. LG G Watch R Power Button, Battery Housing Replacement: step 8, image 1 of 2 LG G Watch R Power Button, Battery Housing Replacement: step 8, image 2 of 2
      • Pry the battery housing from the top right corner using a spudger.
      • Once loosened, remove the battery housing.
      Ask FixBot
    1. LG G Watch R Power Button, Power Button: step 9, image 1 of 3 LG G Watch R Power Button, Power Button: step 9, image 2 of 3 LG G Watch R Power Button, Power Button: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • On the power button, locate a small grey washer on the interior side of the watch.
      • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
      Ask FixBot
7 other people completed this guide.
Author
with
Westley Courchene
3,410 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
168 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 111
All Time: 3,537
