LG G Watch R Battery Replacement Replacement
Views: 32K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
112
All Time:
32,000
Comments: 23
10 comments on steps, 13 guide comments.
Go to guide comments
Completed: 71
71 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The battery can be used to hold a charge that powers the watch for a period of time.
Tools
    1. LG G Watch R Battery Replacement Replacement, Back Case: step 1, image 1 of 2 LG G Watch R Battery Replacement Replacement, Back Case: step 1, image 2 of 2
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      Ask FixBot
    2. LG G Watch R Battery Replacement Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      Ask FixBot
    3. LG G Watch R Battery Replacement Replacement: step 3, image 1 of 1
      • Remove the back case.
      Ask FixBot
    1. LG G Watch R Battery Replacement Replacement, Motherboard: step 4, image 1 of 2 LG G Watch R Battery Replacement Replacement, Motherboard: step 4, image 2 of 2
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      Ask FixBot
    2. LG G Watch R Battery Replacement Replacement: step 5, image 1 of 2 LG G Watch R Battery Replacement Replacement: step 5, image 2 of 2
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      Ask FixBot
    3. LG G Watch R Battery Replacement Replacement: step 6, image 1 of 1
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      Ask FixBot
    1. LG G Watch R Battery Replacement Replacement, Battery Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      Ask FixBot
71 other people completed this guide.
Westley Courchene
3,410 Reputation
14 Guides authored
USF Tampa, Team 1-1, Remmell Fall 2015 Member of USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Members
168 Guides authored
13 Guide Comments
The question is where i can find such battery ?
obada abu alhiga - Reply Share
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - Reply Share
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet - Reply Share
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 112
All Time: 32,000
