Up to 20% off select tools
LG G Watch Gasket Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
25
Past 30 Days:
95
All Time:
1,381
Comments: 5
5 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If moisture has entered your LG G Watch, you will need to replace the gasket, and possibly the battery and the motherboard.
    1. LG G Watch Gasket Replacement, Wristband: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
      • Be prepared to apply some pressure with your fingers to perform the following action.
      • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
      • Grasp the exposed shoulder with the tweezers to perform the next step.
      Ask FixBot
    2. LG G Watch Gasket Replacement: step 2, image 1 of 2 LG G Watch Gasket Replacement: step 2, image 2 of 2
      • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
      • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
      • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
      • Repeat steps 1 and 2 for the other wristband.
      Ask FixBot
    1. LG G Watch Gasket Replacement, Rear Case: step 3, image 1 of 1
      • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
      Ask FixBot
    2. LG G Watch Gasket Replacement: step 4, image 1 of 2 LG G Watch Gasket Replacement: step 4, image 2 of 2
      • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
      • Gently pull the two halves apart.
      Ask FixBot
    1. LG G Watch Gasket Replacement, Gasket: step 5, image 1 of 1
      Buy
      • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
      Ask FixBot
Author
with
Deja Miller
462 Reputation
3 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2014 Member of USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 95
All Time: 1,381
