LG G Vista Screen Replacement
    1. LG G Vista Screen Replacement, Battery: step 1, image 1 of 1
      • Make sure the device is powered off.
      Ask FixBot
    2. LG G Vista Screen Replacement: step 2, image 1 of 1
      • Remove the back cover by gently prying open the case of the device from the charging port.
      Ask FixBot
    3. LG G Vista Screen Replacement: step 3, image 1 of 1
      • Lift the battery out of its place by prying up from the small notch at the base of the battery.
      Ask FixBot
    1. LG G Vista Screen Replacement, Screen: step 4, image 1 of 1
      • Using a Phillips #000 screwdriver, remove all eleven 3.0 mm screws from around the perimeter of the phone.
      Ask FixBot
    2. LG G Vista Screen Replacement: step 5, image 1 of 1
      • Use a plastic spudger or opening tool and run it along the seam of the upper cover.
      • Carefully remove the cover from the device.
      Ask FixBot
    3. LG G Vista Screen Replacement: step 6, image 1 of 1
      • Use the same method to pry off the hard shell covering at the bottom.
      Ask FixBot
    4. LG G Vista Screen Replacement: step 7, image 1 of 1
      • Remove the two 1 mm Phillips #000 screws.
      Ask FixBot
    5. LG G Vista Screen Replacement: step 8, image 1 of 2 LG G Vista Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Gently using tweezers, disconnect the connector that is on the bottom right.
      Ask FixBot
    6. LG G Vista Screen Replacement: step 9, image 1 of 2 LG G Vista Screen Replacement: step 9, image 2 of 2
      • Gently unplug the antenna wires on the bottom left and right sides of the device.
      Ask FixBot
    7. LG G Vista Screen Replacement: step 10, image 1 of 1
      • With your plastic opening tool, gently lift up the bottom edge of the exposed charging port, sliding along the edge until it lifts out.
      Ask FixBot
    8. LG G Vista Screen Replacement: step 11, image 1 of 1
      • Using tweezers, unplug the four connectors.
      Ask FixBot
    9. LG G Vista Screen Replacement: step 12, image 1 of 2 LG G Vista Screen Replacement: step 12, image 2 of 2
      • Remove the antenna wires on both sides of the device.
      Ask FixBot
    10. LG G Vista Screen Replacement: step 13, image 1 of 2 LG G Vista Screen Replacement: step 13, image 2 of 2
      • Carefully lift out the back camera from the device.
      • Lift out the headphone jack in the upper right side of the device.
      Ask FixBot
    11. LG G Vista Screen Replacement: step 14, image 1 of 1
      • Remove the motherboard from the phone.
      Ask FixBot
    12. LG G Vista Screen Replacement: step 15, image 1 of 1
      • Remove the vibration motor from the device.
      • You will be left with the entire display assembly of the device.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,293
