LG G Vista Motherboard Replacement
    1. LG G Vista Motherboard Replacement, Battery: step 1, image 1 of 1
      • Make sure the device is powered off.
      Ask FixBot
    2. LG G Vista Motherboard Replacement: step 2, image 1 of 1
      • Remove the back cover by gently prying open the case of the device from the charging port.
      Ask FixBot
    3. LG G Vista Motherboard Replacement: step 3, image 1 of 1
      • Lift the battery out of its place by prying up from the small notch at the base of the battery.
      Ask FixBot
    1. LG G Vista Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
      Ask FixBot
    2. LG G Vista Motherboard Replacement: step 5, image 1 of 1
      • Remove the hard shell covering the motherboard.
      Ask FixBot
    3. LG G Vista Motherboard Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
      Ask FixBot
    4. LG G Vista Motherboard Replacement: step 7, image 1 of 2 LG G Vista Motherboard Replacement: step 7, image 2 of 2
      • Use the tweezers to remove the four connectors as well as the back camera.
      • Be careful not to directly touch the camera lenses.
      Ask FixBot
    5. LG G Vista Motherboard Replacement: step 8, image 1 of 1
      • Lift up and remove the motherboard from the device.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 797
