LG G Stylo Speaker Replacement
    1. LG G Stylo Speaker Replacement, Battery: step 1, image 1 of 2 LG G Stylo Speaker Replacement, Battery: step 1, image 2 of 2
      • Make sure that you power off the phone before beginning.
      • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
      • There is a small slit that fits the plastic opening tool perfectly on the left side.
      Ask FixBot
    2. LG G Stylo Speaker Replacement: step 2, image 1 of 2 LG G Stylo Speaker Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
      Ask FixBot
    1. LG G Stylo Speaker Replacement, Speaker: step 3, image 1 of 2 LG G Stylo Speaker Replacement, Speaker: step 3, image 2 of 2
      • Carefully use the 3.9mm Phillips #00 screwdriver to remove the eleven visible screws found on the back. The screws to be removed are marked with the given indicators.
      Ask FixBot
    2. LG G Stylo Speaker Replacement: step 4, image 1 of 2 LG G Stylo Speaker Replacement: step 4, image 2 of 2
      • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
      • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
      • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
      Ask FixBot
    3. LG G Stylo Speaker Replacement: step 5, image 1 of 3 LG G Stylo Speaker Replacement: step 5, image 2 of 3 LG G Stylo Speaker Replacement: step 5, image 3 of 3
      • Once you have the plastic back cover exposed you can detach the speaker
      • Indicated on the back panel is where you will use your plastic prying tool to remove the top part from the speaker.
      • The bottom part of the plastic panel contains the speaker which should be placed all as one part.
      Ask FixBot
6 other people completed this guide.
Kimberly Young
779 Reputation
3 Guides authored
USF Tampa, Team 11-7, Cheng Spring 2016 Member of USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 27
All Time: 5,444
