Up to 20% off select tools
LG G Stylo Front Camera Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
87
All Time:
1,868
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your front camera has become damaged any way such as broken lens or water damage, this guide will show you how to replace it.
    1. LG G Stylo Front Camera Replacement, Battery: step 1, image 1 of 2 LG G Stylo Front Camera Replacement, Battery: step 1, image 2 of 2
      • Make sure that you power off the phone before beginning.
      • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
      • There is a small slit that fits the plastic opening tool perfectly on the left side.
      Ask FixBot
    2. LG G Stylo Front Camera Replacement: step 2, image 1 of 2 LG G Stylo Front Camera Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
      Ask FixBot
    1. LG G Stylo Front Camera Replacement, Motherboard: step 3, image 1 of 2 LG G Stylo Front Camera Replacement, Motherboard: step 3, image 2 of 2
      • Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
      Ask FixBot
    2. LG G Stylo Front Camera Replacement: step 4, image 1 of 3 LG G Stylo Front Camera Replacement: step 4, image 2 of 3 LG G Stylo Front Camera Replacement: step 4, image 3 of 3
      • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
      • Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
      • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
      • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
      Ask FixBot
    3. LG G Stylo Front Camera Replacement: step 5, image 1 of 3 LG G Stylo Front Camera Replacement: step 5, image 2 of 3 LG G Stylo Front Camera Replacement: step 5, image 3 of 3
      • Carefully place the plastic opening tool under the ribbons where the cables are connecting and lift up to detach the cables.
      • Keep in mind to be careful with the ribbons, because they are small components and important for the device's functionality.
      • The third photo attached depicts what the ribbons look like when they are successfully detached.
      Ask FixBot
    4. LG G Stylo Front Camera Replacement: step 6, image 1 of 2 LG G Stylo Front Camera Replacement: step 6, image 2 of 2
      • Fully remove the motherboard by prying upward with the plastic opening tool.
      • This step will be quite simple if all the ribbons have been detached correctly.
      Ask FixBot
    1. LG G Stylo Front Camera Replacement, Front Camera: step 7, image 1 of 3 LG G Stylo Front Camera Replacement, Front Camera: step 7, image 2 of 3 LG G Stylo Front Camera Replacement, Front Camera: step 7, image 3 of 3
      • Indicated on the back of the phone is the front camera. To remove the front camera, detach the ribbon cable located on the back of the phone at the top-left.
      • Gently lift up the ribbon with the plastic opening tool. Remove the front camera and replace accordingly.
      • Be careful when removing to avoid harming the device and tearing the attached ribbon.
      Ask FixBot
2 other people completed this guide.
Author
with
Douglas Schmidt
434 Reputation
2 Guides authored
USF Tampa, Team 11-7, Cheng Spring 2016 Member of USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 87
All Time: 1,868
