Introduction
Use this guide to replace a cracked or malfunctioning display on your LG G Pad F 8.0.
LG G Pad F 8.0 replacement screens can be found here. The replacement screen found in the link is compatible with model numbers V495, V496, and UK495.
Place the tablet with the screen facing down.
Open the SIM port on the top right corner of the tablet.
Press the SIM card to pop it out.
Remove the SIM card from the tablet.
Use the iFixit opening tool to pry the plastic backing off of the internal block.
Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
