LG G Pad 7.0 LTE Camera Replacement
  1. LG G Pad 7.0 LTE Camera Replacement, Removing the Back Cover: step 1, image 1 of 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Camera Replacement: step 2, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Camera Replacement, Camera: step 3, image 1 of 1
    • Disconnect camera ribbon cable by prying up on it with a plastic pry tool.
  4. LG G Pad 7.0 LTE Camera Replacement: step 4, image 1 of 1
    Buy
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device (red marker).
  5. LG G Pad 7.0 LTE Camera Replacement: step 5, image 1 of 1
    • Install the new camera into device by gently placing it in its corresponding place until it pops in.
Fadi Bitar
880 Reputation
6 Guides authored
USF Tampa, Team 14-6, Eyestone Fall 2016 Member of USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 519
