LG Front Load Washing Machine Vent Valve Plunger Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
110
All Time:
1,580
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the vent valve plunger in your LG front load washing machine.
The vent valve plunger vents moist air out the back of the washer. The plunger may stick open, which would allow excess liquid to slosh out and drip down the back of the washer.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Tools
    1. LG Front Load Washing Machine Vent Valve Plunger Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Vent Valve Plunger Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Vent Valve Plunger Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Ask FixBot
    2. LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Vent Valve Plunger Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG Front Load Washing Machine Vent Valve Plunger Replacement, Inlet valve information: step 5, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Inlet valve information: step 5, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Inlet valve information: step 5, image 3 of 3
      • To prevent confusion, label each valve and its corresponding hose.
      • You can use masking tape or mark the components themselves.
      • Repeat the labelling procedure for each valve and its corresponding connector.
      Ask FixBot
    2. LG Front Load Washing Machine Vent Valve Plunger Replacement, Disconnect the inlet valve: step 6, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Disconnect the inlet valve: step 6, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Disconnect the inlet valve: step 6, image 3 of 3
      • Disconnect the connectors from the inlet valve.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    3. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 7, image 1 of 1
      • Place a dry rag under the inlet valve to soak up any lingering water.
      Ask FixBot
    4. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 8, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement: step 8, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement: step 8, image 3 of 3
      • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
      Ask FixBot
    5. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 9, image 1 of 2 LG Front Load Washing Machine Vent Valve Plunger Replacement: step 9, image 2 of 2
      • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
      Ask FixBot
    6. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 10, image 1 of 2 LG Front Load Washing Machine Vent Valve Plunger Replacement: step 10, image 2 of 2
      • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
      Ask FixBot
    7. LG Front Load Washing Machine Vent Valve Plunger Replacement: step 11, image 1 of 1
      • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
      Ask FixBot
    8. LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the filters: step 12, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the filters: step 12, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the filters: step 12, image 3 of 3
      • If your replacement part comes with filters pre-installed, skip this step.
      • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
      • Remove the filters.
      Ask FixBot
    9. LG Front Load Washing Machine Vent Valve Plunger Replacement, Unfasten the inlet valve assembly: step 13, image 1 of 1
      • Remove the screws securing the inlet valve assembly.
      Ask FixBot
    10. LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the inlet valve assembly: step 14, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the inlet valve assembly: step 14, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the inlet valve assembly: step 14, image 3 of 3
      • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
      Ask FixBot
    1. LG Front Load Washing Machine Vent Valve Plunger Replacement, Reposition the vent hose: step 15, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Reposition the vent hose: step 15, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Reposition the vent hose: step 15, image 3 of 3
      • Loosen the fastener securing the vent hose.
      • Lift the vent hose straight off the drum to expose the vent valve plunger.
      Ask FixBot
    2. LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the vent valve plunger: step 16, image 1 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the vent valve plunger: step 16, image 2 of 3 LG Front Load Washing Machine Vent Valve Plunger Replacement, Remove the vent valve plunger: step 16, image 3 of 3
      • Use two flathead screwdrivers, or similar tools, to pry the vent valve plunger up enough to grip it with your fingers.
      • Pull the plunger straight up to remove it.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 110
All Time: 1,580
