Up to 20% off select tools
LG Front Load Washing Machine Rotor Position Sensor Replacement
Views: 6K
View statistics:
Past 24 Hours:
11
Past 7 Days:
104
Past 30 Days:
439
All Time:
5,960
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the rotor position sensor in your LG front load washing machine.
The rotor position sensor is a Hall effect sensor that detects the primary motor's position, direction, and speed.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. LG Front Load Washing Machine Rotor Position Sensor Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Ask FixBot
    2. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG Front Load Washing Machine Rotor Position Sensor Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the rotor: step 5, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the rotor: step 5, image 2 of 2
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      Ask FixBot
    2. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor: step 6, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor: step 6, image 2 of 2
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      Ask FixBot
    1. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the motor harness clamps: step 7, image 1 of 1
      • Remove the screw(s) securing the motor harness clamps.
      Ask FixBot
    2. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the stator: step 8, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the stator: step 8, image 2 of 2
      • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
      • Remove the bolt(s) securing the stator.
      • During reassembly, refasten the screws in a "star" pattern.
      Ask FixBot
    3. LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: step 9, image 1 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: step 9, image 2 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: step 9, image 3 of 3
      • Don't pull the stator too far away from the device, as it's still connected by wires.
      • Pull the stator off of the drum and flip it so its rear is facing upward.
      • Note the position of the stator before continuing, as you will need it face the proper direction during reassembly.
      Ask FixBot
    4. LG Front Load Washing Machine Rotor Position Sensor Replacement, Disconnect the rotor position sensor: step 10, image 1 of 2 LG Front Load Washing Machine Rotor Position Sensor Replacement, Disconnect the rotor position sensor: step 10, image 2 of 2
      • Pull the rotor position sensor connector straight out of its socket to disconnect it.
      Ask FixBot
    5. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: step 11, image 1 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: step 11, image 2 of 3 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: step 11, image 3 of 3
      • Use your fingers to unclip the rotor position sensor from the stator.
      • Pull the sensor away from the stator to completely unclip it.
      • Remove the rotor position sensor.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Thank you and your video, I was able to replace my motor rotor position sensor easily and avoided throwing away a good washer (8 years old), $700 for a new one, not to mention the damage to the environment. Need sockets, 17mm and 10mm. I recommend to test the resistance of the part(see Felix Techno Aid video), before installation to make sure the part is good. I want to acknowledge other good videos on this subject, Felix Techno Aid, Appliance Parts Pros.com, Repair Clinic.com and IFixit by Bill Gilbert. Thank you all for your videos.
Prasad Gogineni - Reply Share
I did not have to disconnect the water hoses or remove the top cover as shown in this video. I had lot of room in the laundry to move it around. This video is missing the step to show removal of the back panel to get access to the motor (before step 5).
Past 24 Hours: 11
Past 7 Days: 104
Past 30 Days: 439
All Time: 5,960
