Up to 20% off select tools
LG Front Load Washing Machine Pump Assembly Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
40
Past 7 Days:
121
Past 30 Days:
561
All Time:
7,197
Comments: 8
5 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
Use this guide to replace the pump assembly in your LG front load washing machine.
The pump assembly drains the tub and expels wastewater out of the washer. It includes the drain pump and drain filter housing.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
    1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Ask FixBot
    2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG Front Load Washing Machine Pump Assembly Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: step 8, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Ask FixBot
    3. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Remove the screw(s) securing the detergent dispenser.
      Ask FixBot
    4. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: step 10, image 3 of 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Ask FixBot
    5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: step 11, image 3 of 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Ask FixBot
    1. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: step 12, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Open the door: step 12, image 2 of 2
      • Open the front door completely.
      Ask FixBot
    2. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: step 13, image 3 of 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Ask FixBot
    3. LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 14, image 3 of 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Ask FixBot
    4. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: step 15, image 3 of 3
      • Use your fingers to pull the boot off its lip on the front panel.
      Ask FixBot
    5. LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 16, image 3 of 3
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      Ask FixBot
    6. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: step 17, image 3 of 3
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      Ask FixBot
    7. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: step 18, image 3 of 3
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      Ask FixBot
    8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: step 19, image 1 of 1
      • Remove the screw(s) securing the filter trim.
      Ask FixBot
    9. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: step 20, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: step 20, image 2 of 2
      • Pull the filter trim straight off the front panel to remove it.
      Ask FixBot
    10. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: step 21, image 1 of 1
      • Remove the screw(s) securing the lower front panel.
      Ask FixBot
    11. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: step 22, image 1 of 1
      • Remove the screw(s) securing the door latch.
      Ask FixBot
    12. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: step 23, image 3 of 3
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      Ask FixBot
    13. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: step 24, image 3 of 3
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      Ask FixBot
    14. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: step 25, image 3 of 3
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      Ask FixBot
    15. LG Front Load Washing Machine Pump Assembly Replacement: step 26, image 1 of 1
      • Remove the front panel.
      Ask FixBot
    1. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: step 27, image 3 of 3
      • Twist and remove the pump filter.
      Ask FixBot
    2. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: step 28, image 3 of 3
      • Push the drain hose through its hole in the chassis until it's completely inside the device.
      Ask FixBot
    3. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: step 29, image 3 of 3
      • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
      Ask FixBot
    4. LG Front Load Washing Machine Pump Assembly Replacement: step 30, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement: step 30, image 2 of 2
      • Fold the plastic wrap away from the cables, enough to expose the connector(s).
      • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
      Ask FixBot
    5. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: step 31, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: step 31, image 2 of 2
      • Disconnect the connector(s) attached to the pump cable.
      Ask FixBot
    6. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: step 32, image 3 of 3
      • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
      Ask FixBot
    7. LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement: step 33, image 3 of 3
      • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
      • Pull the drain hose straight off its connection on the assembly.
      Ask FixBot
    8. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: step 34, image 3 of 3
      • Repeat the last two steps for the pump hose.
      Ask FixBot
    9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: step 35, image 1 of 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: step 35, image 2 of 2
      • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
      Ask FixBot
    10. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 1 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 2 of 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: step 36, image 3 of 3
      • Lift the pump assembly out of its location in the frame to remove it.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
5 other people completed this guide.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
3 Guide Comments
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Reply Share
Wow, that's intense. I wonder if I can just prop it up and get to that pump from the bottom? I don't have a jack stand or anything but I saw someone lean it back into a metal step stool.
Doyle Stadt - Reply Share
Thank you so much. Great instructions and pictures.
Roy - Reply Share
Past 24 Hours: 40
Past 7 Days: 121
Past 30 Days: 561
All Time: 7,197
