Up to 20% off select tools
LG Front Load Washing Machine Door Latch Replacement
Views: 13K
View statistics:
Past 24 Hours:
22
Past 7 Days:
167
Past 30 Days:
829
All Time:
13,305
Comments: 5
5 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the door latch in your LG front load washing machine.
The door latch is electronically actuated. If your washer's door won't latch, you may need to replace this part.
This guide will work for most LG front-load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
    1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Door Latch Replacement, Open the door: step 2, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: step 2, image 2 of 2
      • Open the front door completely.
      Ask FixBot
    2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: step 3, image 3 of 3
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      Ask FixBot
    3. LG Front Load Washing Machine Door Latch Replacement: step 4, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement: step 4, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement: step 4, image 3 of 3
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      Ask FixBot
    4. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: step 5, image 3 of 3
      • Use your fingers to pull the boot off its lip in the front panel.
      Ask FixBot
    5. LG Front Load Washing Machine Door Latch Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement: step 6, image 3 of 3
      • Work your fingers around the boot's perimeter until it's completely separated from the panel.
      Ask FixBot
    6. LG Front Load Washing Machine Door Latch Replacement: step 7, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement: step 7, image 2 of 2
      • Use your hands to fold the boot into the drum.
      Ask FixBot
    7. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: step 8, image 1 of 1
      • Remove the screw(s) securing the door latch.
      Ask FixBot
    8. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 1 of 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 2 of 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: step 9, image 3 of 3
      • Reach between the boot and the chassis to grip the door latch.
      • Pull the door latch out of its slot in the chassis to expose it.
      • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
      Ask FixBot
    9. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: step 10, image 1 of 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: step 10, image 2 of 2
      • Disconnect the cable harness from the door latch.
      • Always grip cables by their connectors and not the wires themselves.
      • Remove the door latch.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
4 other people completed this guide.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 22
Past 7 Days: 167
Past 30 Days: 829
All Time: 13,305
