Up to 20% off select tools
LG Front Load Washing Machine Control Panel Replacement
Views: 7K
View statistics:
Past 24 Hours:
13
Past 7 Days:
109
Past 30 Days:
421
All Time:
7,009
Comments: 3
3 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the control panel in your LG front load washing machine.
The control panel contains the buttons, dials, and control knob to adjust the wash settings. If you have a broken control knob or button, you can access it by following this guide.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG Front Load Washing Machine Control Panel Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Remove the screw(s) securing the control panel.
      Ask FixBot
    3. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Remove the screw(s) securing the detergent dispenser.
      Ask FixBot
    4. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 3 of 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Ask FixBot
    5. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 3 of 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Ask FixBot
    6. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: step 12, image 1 of 1
      • Flip the control panel over.
      • Remove the screw(s) securing the control panel board.
      Ask FixBot
    7. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: step 13, image 3 of 3
      • Pull the control panel board out of its slot and remove it.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
4 other people completed this guide.
Author
with
Bill Gilbert
41,141 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 109
Past 30 Days: 421
All Time: 7,009
