Up to 20% off select tools
LG Fortune Motherboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
68
All Time:
1,202
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips PH000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If you have a bad motherboard or are using it for parts this guide with show you how to retrieve the motherboard from your LG Fortune phone.
    1. LG Fortune Motherboard Replacement, Battery: step 1, image 1 of 2 LG Fortune Motherboard Replacement, Battery: step 1, image 2 of 2
      • Use the slit on the bottom right side of the phone to open the back cover of your phone.
      • It will be the bottom left of the phone if looking at it from the back.
      • Slowly pry the back cover off the phone starting from the bottom up to the top.
      Ask FixBot
    2. LG Fortune Motherboard Replacement: step 2, image 1 of 2 LG Fortune Motherboard Replacement: step 2, image 2 of 2
      • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
      Ask FixBot
    1. LG Fortune Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG Fortune Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG Fortune Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
      • Remove the back panelling from the device with your fingers or a spudger.
      • Work slowly side to side to release this back casing and expose the motherboard.
      Ask FixBot
    2. LG Fortune Motherboard Replacement: step 4, image 1 of 1
      • Place a spudger or an opening tool under the edge of the video card press connector and pry straight up to disconnect it from the motherboard.
      • Using the metal spudger as shown in the photos has the potential to damage your device.
      Ask FixBot
    3. LG Fortune Motherboard Replacement: step 5, image 1 of 1
      • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
      • Using a metal spudger as shown in the photos could potentially damage your device.
      Ask FixBot
    4. LG Fortune Motherboard Replacement: step 6, image 1 of 1
      • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
      • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
      Ask FixBot
    5. LG Fortune Motherboard Replacement: step 7, image 1 of 1
      • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Cori Johnson
537 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 1,202
