Up to 20% off select tools
LG Fortune 2 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
61
All Time:
889
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 50 minutes - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If you've dropped your LG Fortune 2 and noticed screen cracks or greenish imperfections (backlight bleed), it may be time to replace your screen. The process is very straightforward, requires two tools, and will help salvage your phone. Don't overpay for a professional or buy a new phone. Instead say "I fix it" and use this guide.
    1. LG Fortune 2 Screen Replacement, Screen: step 1, image 1 of 3 LG Fortune 2 Screen Replacement, Screen: step 1, image 2 of 3 LG Fortune 2 Screen Replacement, Screen: step 1, image 3 of 3
      • Use the slit on the bottom left side of the phone to open the back cover using your hand.
      • Use the groove at the bottom of the phone to remove the battery.
      • Remove the battery for safety purposes before moving on to step 2.
      Ask FixBot
    2. LG Fortune 2 Screen Replacement: step 2, image 1 of 3 LG Fortune 2 Screen Replacement: step 2, image 2 of 3 LG Fortune 2 Screen Replacement: step 2, image 3 of 3
      • Remove the twelve 4 mm screws on the back paneling using a Phillips #000 screwdriver.
      Ask FixBot
    3. LG Fortune 2 Screen Replacement: step 3, image 1 of 3 LG Fortune 2 Screen Replacement: step 3, image 2 of 3 LG Fortune 2 Screen Replacement: step 3, image 3 of 3
      • Use the plastic opening tool to wedge between the glass screen and midframe.
      • Wedging the glass screen from the midframe will require some force, so be careful not to damage/snap the opening tool, as you will need it for later steps.
      • Make sure all screws are removed prior to this step, as not doing so will make it impossible to wedge the screen from the midframe.
      Ask FixBot
    4. LG Fortune 2 Screen Replacement: step 4, image 1 of 2 LG Fortune 2 Screen Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to release the flex cable.
      • Pry off the front camera located above the SIM card slot using the plastic opening tool.
      Ask FixBot
    5. LG Fortune 2 Screen Replacement: step 5, image 1 of 3 LG Fortune 2 Screen Replacement: step 5, image 2 of 3 LG Fortune 2 Screen Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to pry off the motherboard from the rest of the device.
      • Preferably, start from the bottom of the phone as there is more space to wedge the plastic opening tool into.
      • Handle the motherboard with care, as it is the backbone of the device
      Ask FixBot
    6. LG Fortune 2 Screen Replacement: step 6, image 1 of 3 LG Fortune 2 Screen Replacement: step 6, image 2 of 3 LG Fortune 2 Screen Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to remove the ear speaker on the underside of the device.
      • Remove the headphone jack using the plastic opening tool.
      • The headphone jack is protected by a small rubber piece that will need to be removed by scraping it with the prying tool.
      • The headphone jack is covered by a fairly strong adhesive, so extra force may be required. Do not damage the piece.
      • Remove the volume rocker/button on the side of the phone using the plastic opening tool.
      Ask FixBot
    7. LG Fortune 2 Screen Replacement: step 7, image 1 of 2 LG Fortune 2 Screen Replacement: step 7, image 2 of 2
      • Disconnect the loudspeaker antenna on the bottom of the phone using the plastic opening tool.
      • Scrape off the small rubber piece from the antenna.
      • Photo 2 shows the new LCD screen replacement with frame.
      • If you order the glass and LCD in one piece without the frame, you will need to remove the previous glass and LCD with some heat around the edges and use the plastic opening tool to wedge between them and the frame.
      • To mitigate screen damage, use a glass screen protector and a cell phone case.
      Ask FixBot
Author
with
Bryam Ochoa
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 61
All Time: 889
