LG Escape (p870) Rear Camera Replacement
    1. LG Escape (p870) Rear Camera Replacement, Battery: step 1, image 1 of 2 LG Escape (p870) Rear Camera Replacement, Battery: step 1, image 2 of 2
      • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
      Ask FixBot
    2. LG Escape (p870) Rear Camera Replacement: step 2, image 1 of 2 LG Escape (p870) Rear Camera Replacement: step 2, image 2 of 2
      • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
      • You now have access to:
      • Your SD card
      • Your SIM card
      • Your device's serial numbers
      Ask FixBot
    1. LG Escape (p870) Rear Camera Replacement, Loudspeaker Assembly: step 3, image 1 of 1
      • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
      Ask FixBot
    2. LG Escape (p870) Rear Camera Replacement: step 4, image 1 of 2 LG Escape (p870) Rear Camera Replacement: step 4, image 2 of 2
      • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
      • Pry the speaker assembly out of the phone and set it aside
      Ask FixBot
    1. LG Escape (p870) Rear Camera Replacement, Rear Camera: step 5, image 1 of 1
      • Remove the remaining 6 screws securing the plastic frame to the back housing
      Ask FixBot
    2. LG Escape (p870) Rear Camera Replacement: step 6, image 1 of 3 LG Escape (p870) Rear Camera Replacement: step 6, image 2 of 3 LG Escape (p870) Rear Camera Replacement: step 6, image 3 of 3
      • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
      • Continue working your way around the phone, prying carefully with your prying tool
      • When you work the frame free, set it aside
      Ask FixBot
    3. LG Escape (p870) Rear Camera Replacement: step 7, image 1 of 1
      • Use a plastic spudger or safe-open pry tool to release the camera's flex cable from its connector
      • Remove the camera from the housing and set it aside
      Ask FixBot
Brad
1,956 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 102
All Time: 905
