LG Escape (p870) LCD Screen Replacement
    1. LG Escape (p870) LCD Screen Replacement, Battery: step 1, image 1 of 2 LG Escape (p870) LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
      Ask FixBot
    2. LG Escape (p870) LCD Screen Replacement: step 2, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 2, image 2 of 2
      • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
      • You now have access to:
      • Your SD card
      • Your SIM card
      • Your device's serial numbers
      Ask FixBot
    1. LG Escape (p870) LCD Screen Replacement, Loudspeaker Assembly: step 3, image 1 of 1
      • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
      Ask FixBot
    2. LG Escape (p870) LCD Screen Replacement: step 4, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 4, image 2 of 2
      • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
      • Pry the speaker assembly out of the phone and set it aside
      Ask FixBot
    1. LG Escape (p870) LCD Screen Replacement, Touch screen/digitizer: step 5, image 1 of 1
      • Remove the remaining 6 screws securing the plastic frame to the back housing
      Ask FixBot
    2. LG Escape (p870) LCD Screen Replacement: step 6, image 1 of 3 LG Escape (p870) LCD Screen Replacement: step 6, image 2 of 3 LG Escape (p870) LCD Screen Replacement: step 6, image 3 of 3
      • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
      • Continue working your way around the phone, prying carefully with your prying tool
      • When you work the frame free, set it aside
      Ask FixBot
    3. LG Escape (p870) LCD Screen Replacement: step 7, image 1 of 1
      • Wifi and cell service antennas
      • LCD connector
      • Back camera connector
      • Front camera connector
      • Touch screen/ digitizer connector
      • Charger port connector
      • Headphone jack connector
      Ask FixBot
    4. LG Escape (p870) LCD Screen Replacement: step 8, image 1 of 3 LG Escape (p870) LCD Screen Replacement: step 8, image 2 of 3 LG Escape (p870) LCD Screen Replacement: step 8, image 3 of 3
      • With a spudger or safe open pry tool, carefully detach the LCD flex connector
      • Release the two antennae from their connectors
      • Release the back camera's flex from its connector
      Ask FixBot
    5. LG Escape (p870) LCD Screen Replacement: step 9, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 9, image 2 of 2
      • Release the charging port flex from its connector
      • Release the front camera's flex from its connector
      • Release the touch screen/digitizer's flex cable from its connector
      Ask FixBot
    6. LG Escape (p870) LCD Screen Replacement: step 10, image 1 of 1
      • Release the headphone jack's flex cable from its connector
      Ask FixBot
    7. LG Escape (p870) LCD Screen Replacement: step 11, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • With a pair of tweezers, VERY carefully pull the volume button flex out of the rear housing
      • Repeat the process with the power button flex cable
      • The power button and volume button flex cables will tear very easily, so be cautious
      Ask FixBot
    8. LG Escape (p870) LCD Screen Replacement: step 12, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 12, image 2 of 2
      • Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
      • Set the motherboard aside
      Ask FixBot
    9. LG Escape (p870) LCD Screen Replacement: step 13, image 1 of 2 LG Escape (p870) LCD Screen Replacement: step 13, image 2 of 2
      • Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
      • Gently pry on the bezel to release the clips adhering the screen to the mid-frame
      • Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
      • Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
      • After carefully threading the digitizer and outer housing/bezel from the middle bracket you'll notice the digitizer is held on by a band of very strong adhesive - this will be destroyed when you take off the old digitizer. When you replace your digitizer you can use double-sided tape or epoxy to hold the new digitizer on the bezel.
      Ask FixBot
    1. LG Escape (p870) LCD Screen Replacement, LCD Screen: step 14, image 1 of 1
      • Peel off the adhesive portion of the LCD ribbon cable from the back of the phone
      Ask FixBot
    2. LG Escape (p870) LCD Screen Replacement: step 15, image 1 of 1
      • Lift the LCD from its bottom edge and work the ribbon cable carefully through the hole
      • Set the LCD aside
      Ask FixBot
Brad
1,956 Reputation
10 Guides authored
1 Guide Comment
Just replaced my broken screen by following these directions. Back together now and all works well except the camera. I'm just getting a fuzzy gray or green screen. Took apart a second time to make sure the camera connectors were installed properly and they seem to be. Put back together again but camera is still screwed up.
Any suggestions?
Chuck - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 109
All Time: 3,272
