LG Encore GT550 Earphone Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
80
All Time:
742
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The speaker on the earpiece of a cell phone is arguably the most important aspect of the phone. Used to make phone calls, it is a necessity to have the earphone working at full capacity. Phone's earphones can get messed up by things as simple as sweat and dust and need fixing, but not to worry.
Before completing this repair, be sure you're comfortable using a Phillips #0 screwdriver. You will need it for the repair. You will need to be comfortable with a plastic prying tool as well, so make sure you can use one without harming yourself or the product! Finally, be careful when removing the battery and when handling the internals of the phone -- make sure you have dry hands!
By replacing this piece, the phone will once again be able to function as well as it was designed to. If you find yourself needing a new earphone for your LG Encore GT550, please follow this step-by-step guide.
Tools
    1. LG Encore GT550 Earphone Replacement, Earphone: step 1, image 1 of 2 LG Encore GT550 Earphone Replacement, Earphone: step 1, image 2 of 2
      • Slide off the back cover of the phone.
      Ask FixBot
    2. LG Encore GT550 Earphone Replacement: step 2, image 1 of 1
      • Remove the battery by gently lifting it up from the bottom.
      Ask FixBot
    3. LG Encore GT550 Earphone Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the six screws around the edge of the device.
      Ask FixBot
    4. LG Encore GT550 Earphone Replacement: step 4, image 1 of 2 LG Encore GT550 Earphone Replacement: step 4, image 2 of 2
      • Using a prying tool, separate the frame of the phone.
      Ask FixBot
    5. LG Encore GT550 Earphone Replacement: step 5, image 1 of 2 LG Encore GT550 Earphone Replacement: step 5, image 2 of 2
      • Using a prying tool, separate the screen from the motherboard.
      Ask FixBot
    6. LG Encore GT550 Earphone Replacement: step 6, image 1 of 1
      • Remove the speakerphone and replace it.
      Ask FixBot
Lindsey Harding
501 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-4, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 80
All Time: 742
