LG Encore GT550 Audio Jack Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
81
All Time:
691
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you need to replace the audio jack in your LG Encore GT550, follow this guide.
Tools
    1. LG Encore GT550 Audio Jack Replacement, Audio Jack: step 1, image 1 of 2 LG Encore GT550 Audio Jack Replacement, Audio Jack: step 1, image 2 of 2
      • Turn the device over so the backside is facing up.
      • Use your fingers or an opening tool to remove the back cover in order to expose the battery.
      Ask FixBot
    2. LG Encore GT550 Audio Jack Replacement: step 2, image 1 of 2 LG Encore GT550 Audio Jack Replacement: step 2, image 2 of 2
      • Use your fingers or a spudger to remove the battery. Lift it from the side opposite of the camera.
      Ask FixBot
    3. LG Encore GT550 Audio Jack Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove six screws around the perimeter of the phone.
      Ask FixBot
    4. LG Encore GT550 Audio Jack Replacement: step 4, image 1 of 2 LG Encore GT550 Audio Jack Replacement: step 4, image 2 of 2
      • Place the opening tool in the seam of the device and pry around the perimeter to separate the top case from the bottom case.
      Ask FixBot
    5. LG Encore GT550 Audio Jack Replacement: step 5, image 1 of 2 LG Encore GT550 Audio Jack Replacement: step 5, image 2 of 2
      • Place the opening tool on the top on the device between the phone casing and motherboard.
      • Separate the screen and the motherboard.
      Ask FixBot
    6. LG Encore GT550 Audio Jack Replacement: step 6, image 1 of 1
      • Push the audio jack out and replace it.
      Ask FixBot
Lindsey Harding
501 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-4, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G4
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 81
All Time: 691
