LG Enact Charging Port Replacement
    1. LG Enact Charging Port Replacement, Battery: step 1, image 1 of 3 LG Enact Charging Port Replacement, Battery: step 1, image 2 of 3 LG Enact Charging Port Replacement, Battery: step 1, image 3 of 3
      • Open the back cover by prying into the bottom tab with an iFixit opening tool.
      Ask FixBot
    2. LG Enact Charging Port Replacement: step 2, image 1 of 3 LG Enact Charging Port Replacement: step 2, image 2 of 3 LG Enact Charging Port Replacement: step 2, image 3 of 3
      • Use an iFixit opening tool to remove the battery.
      Ask FixBot
    1. LG Enact Charging Port Replacement, Speaker: step 3, image 1 of 1
      • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
      Ask FixBot
    2. LG Enact Charging Port Replacement: step 4, image 1 of 2 LG Enact Charging Port Replacement: step 4, image 2 of 2
      • Use an iFixit opening pick to pop out the speaker.
      Ask FixBot
    1. LG Enact Charging Port Replacement, Midframe: step 5, image 1 of 2 LG Enact Charging Port Replacement, Midframe: step 5, image 2 of 2
      • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
      Ask FixBot
    2. LG Enact Charging Port Replacement: step 6, image 1 of 1
      • Use the iFixit opening pick to pry out the midframe.
      Ask FixBot
    1. LG Enact Charging Port Replacement, Motherboard: step 7, image 1 of 2 LG Enact Charging Port Replacement, Motherboard: step 7, image 2 of 2
      • Unplug the four ports connected to the motherboard.
      • Disconnect the two wires on top of the battery.
      • Disconnect the two wires under the battery.
      Ask FixBot
    2. LG Enact Charging Port Replacement: step 8, image 1 of 2 LG Enact Charging Port Replacement: step 8, image 2 of 2
      • Slowly pry out the motherboard using an iFixit opening pick.
      Ask FixBot
    1. LG Enact Charging Port Replacement, Charging Port: step 9, image 1 of 2 LG Enact Charging Port Replacement, Charging Port: step 9, image 2 of 2
      • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 68
All Time: 397
