Up to 20% off select tools
LG Enact Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
54
All Time:
469
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A camera in a device captures moments and memories, but with extensive use, the camera component may encounter issues or stop functioning properly. If you've noticed blurry images, black screens, or error messages when trying to access your camera, it could indicate a problem with the camera module itself.
In this guide, we'll walk you through the steps to safely remove and replace the camera in the LG Enact. This guide will help you address potential camera-related issues. Remember to power off your device before starting the camera replacement process to ensure a safe and effective procedure.
    1. LG Enact Camera Replacement, Battery: step 1, image 1 of 3 LG Enact Camera Replacement, Battery: step 1, image 2 of 3 LG Enact Camera Replacement, Battery: step 1, image 3 of 3
      • Open the back cover by prying into the bottom tab with an iFixit opening tool.
      Ask FixBot
    2. LG Enact Camera Replacement: step 2, image 1 of 3 LG Enact Camera Replacement: step 2, image 2 of 3 LG Enact Camera Replacement: step 2, image 3 of 3
      • Use an iFixit opening tool to remove the battery.
      Ask FixBot
    1. LG Enact Camera Replacement, Speaker: step 3, image 1 of 1
      • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
      Ask FixBot
    2. LG Enact Camera Replacement: step 4, image 1 of 2 LG Enact Camera Replacement: step 4, image 2 of 2
      • Use an iFixit opening pick to pop out the speaker.
      Ask FixBot
    1. LG Enact Camera Replacement, Midframe: step 5, image 1 of 2 LG Enact Camera Replacement, Midframe: step 5, image 2 of 2
      • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
      Ask FixBot
    2. LG Enact Camera Replacement: step 6, image 1 of 1
      • Use the iFixit opening pick to pry out the midframe.
      Ask FixBot
    1. LG Enact Camera Replacement, Camera: step 7, image 1 of 1
      • Slowly, pop the camera lens out of the socket.
      Ask FixBot
    2. LG Enact Camera Replacement: step 8, image 1 of 2 LG Enact Camera Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the camera assembly connector.
      Ask FixBot
Author
with
pranay_munikuntla
621 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 54
All Time: 469
