LG EnV VX9900 LCD Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
43
All Time:
1,777
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
For an easier time working with the LCD Screen, follow the Installation Guide for the Circuit Board and Full Key Board.
Tools
    1. LG EnV VX9900 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Place the phone so the screen side is facing down.
      • Locate the latch at the end of the phone, opposite of the camera.
      Ask FixBot
    2. LG EnV VX9900 LCD Screen Replacement: step 2, image 1 of 1
      • Push/pull the latch away from the camera, causing the battery to pop out.
      Ask FixBot
    3. LG EnV VX9900 LCD Screen Replacement: step 3, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: step 4, image 1 of 2 LG EnV VX9900 LCD Screen Replacement, Circuit Board and Full Key Board: step 4, image 2 of 2
      • Remove the 5 screw covers on the back of the phone using a Push Pin.
      Ask FixBot
    2. LG EnV VX9900 LCD Screen Replacement: step 5, image 1 of 1
      • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
      • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
      Ask FixBot
    3. LG EnV VX9900 LCD Screen Replacement: step 6, image 1 of 2 LG EnV VX9900 LCD Screen Replacement: step 6, image 2 of 2
      • Open the phone.
      Ask FixBot
    4. LG EnV VX9900 LCD Screen Replacement: step 7, image 1 of 2 LG EnV VX9900 LCD Screen Replacement: step 7, image 2 of 2
      • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
      • Prying open the part just to the left of the right hinge can be difficult.
      • Remove the back colored casing and set it to the side.
      Ask FixBot
    5. LG EnV VX9900 LCD Screen Replacement: step 8, image 1 of 2 LG EnV VX9900 LCD Screen Replacement: step 8, image 2 of 2
      • Gently pry and detach the connection located near the hinge with fingers.
      Ask FixBot
    6. LG EnV VX9900 LCD Screen Replacement: step 9, image 1 of 2 LG EnV VX9900 LCD Screen Replacement: step 9, image 2 of 2
      • The circuit board and the key board will be attached, as shown in the second picture.
      • Lift them both out from the rest of the phone.
      • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
      Ask FixBot
    1. LG EnV VX9900 LCD Screen Replacement, LCD Screen: step 10, image 1 of 1
      • After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
      Ask FixBot
    2. LG EnV VX9900 LCD Screen Replacement: step 11, image 1 of 1
      • Careful! The paint is easy to scratch.
      • Remove the 4 screw covers from top piece of phone by using a Push Pin.
      Ask FixBot
    3. LG EnV VX9900 LCD Screen Replacement: step 12, image 1 of 1
      • Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
      Ask FixBot
    4. LG EnV VX9900 LCD Screen Replacement: step 13, image 1 of 3 LG EnV VX9900 LCD Screen Replacement: step 13, image 2 of 3 LG EnV VX9900 LCD Screen Replacement: step 13, image 3 of 3
      • Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires.
      • Pry open the colored casing using the Plastic Pry Tool.
      • Remove the number pad and place it to the side.
      Ask FixBot
    5. LG EnV VX9900 LCD Screen Replacement: step 14, image 1 of 2 LG EnV VX9900 LCD Screen Replacement: step 14, image 2 of 2
      • Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
      Ask FixBot
    6. LG EnV VX9900 LCD Screen Replacement: step 15, image 1 of 1
      • The pieces connected by wires are magnets and are removable.
      • Remove the LCD Screen.
      Ask FixBot
2 other people completed this guide.
Cal Poly, Team 15-15, Forte Spring 2012 Member of Cal Poly, Team 15-15, Forte Spring 2012
CPSU-FORTE-S12S15G15
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 43
All Time: 1,777
