LG EnV Touch VX11000 Screen Assembly Replacement
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: step 1, image 1 of 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
    Ask FixBot
  2. LG EnV Touch VX11000 Screen Assembly Replacement: step 2, image 1 of 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
    Ask FixBot
  3. LG EnV Touch VX11000 Screen Assembly Replacement: step 3, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement: step 3, image 2 of 2
    • Lift the edge of the battery to remove it.
    Ask FixBot
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: step 4, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: step 4, image 2 of 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
    Ask FixBot
  5. LG EnV Touch VX11000 Screen Assembly Replacement: step 5, image 1 of 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
    Ask FixBot
  6. LG EnV Touch VX11000 Screen Assembly Replacement: step 6, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement: step 6, image 2 of 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
    Ask FixBot
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: step 7, image 1 of 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: step 7, image 2 of 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: step 7, image 3 of 3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
    Ask FixBot
  8. LG EnV Touch VX11000 Screen Assembly Replacement: step 8, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement: step 8, image 2 of 2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
    Ask FixBot
  9. LG EnV Touch VX11000 Screen Assembly Replacement: step 9, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement: step 9, image 2 of 2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
    Ask FixBot
  10. LG EnV Touch VX11000 Screen Assembly Replacement: step 10, image 1 of 1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
    Ask FixBot
  11. LG EnV Touch VX11000 Screen Assembly Replacement: step 11, image 1 of 3 LG EnV Touch VX11000 Screen Assembly Replacement: step 11, image 2 of 3 LG EnV Touch VX11000 Screen Assembly Replacement: step 11, image 3 of 3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
    Ask FixBot
  12. LG EnV Touch VX11000 Screen Assembly Replacement: step 12, image 1 of 2 LG EnV Touch VX11000 Screen Assembly Replacement: step 12, image 2 of 2
    • Unplug the connector from the screen.
    Ask FixBot
3 other people completed this guide.
Rachel Smith
593 Reputation
5 Guides authored
Cal Poly, Team 13-2, Forte Fall 2013 Member of Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 1,505
