LG Dare Earpiece Replacement
    1. LG Dare Earpiece Replacement, Battery: step 1, image 1 of 2 LG Dare Earpiece Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
      Ask FixBot
    2. LG Dare Earpiece Replacement: step 2, image 1 of 3 LG Dare Earpiece Replacement: step 2, image 2 of 3 LG Dare Earpiece Replacement: step 2, image 3 of 3
      • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
      Ask FixBot
    1. LG Dare Earpiece Replacement, Logic Board: step 3, image 1 of 2 LG Dare Earpiece Replacement, Logic Board: step 3, image 2 of 2
      • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
      Ask FixBot
    2. LG Dare Earpiece Replacement: step 4, image 1 of 3 LG Dare Earpiece Replacement: step 4, image 2 of 3 LG Dare Earpiece Replacement: step 4, image 3 of 3
      • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
      • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
      • The side buttons may fall out when removing the back plastic.
      Ask FixBot
    3. LG Dare Earpiece Replacement: step 5, image 1 of 3 LG Dare Earpiece Replacement: step 5, image 2 of 3 LG Dare Earpiece Replacement: step 5, image 3 of 3
      • Pull off the back plastic panel.
      • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
      Ask FixBot
    4. LG Dare Earpiece Replacement: step 6, image 1 of 1
      • Disconnect the three ribbon connectors from the motherboard.
      Ask FixBot
    5. LG Dare Earpiece Replacement: step 7, image 1 of 3 LG Dare Earpiece Replacement: step 7, image 2 of 3 LG Dare Earpiece Replacement: step 7, image 3 of 3
      • Remove the LED.
      • Remove the camera connector.
      • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
      Ask FixBot
    6. LG Dare Earpiece Replacement: step 8, image 1 of 1
      • Open the USB port cover.
      Ask FixBot
    7. LG Dare Earpiece Replacement: step 9, image 1 of 3 LG Dare Earpiece Replacement: step 9, image 2 of 3 LG Dare Earpiece Replacement: step 9, image 3 of 3
      • Use the opening tool to lift up the green logic board in all areas and remove it.
      • The logic board may require some force to remove because it is taped to the plastic frame.
      • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
      Ask FixBot
    1. LG Dare Earpiece Replacement, Earpiece: step 10, image 1 of 3 LG Dare Earpiece Replacement, Earpiece: step 10, image 2 of 3 LG Dare Earpiece Replacement, Earpiece: step 10, image 3 of 3
      • Peel off the gold and green tape near the bottom of the phone.
      • Peel off the blue tape covering the speaker connector.
      • Peel off the gold tape to the left of the earpiece speaker.
      • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
      Ask FixBot
    2. LG Dare Earpiece Replacement: step 11, image 1 of 2 LG Dare Earpiece Replacement: step 11, image 2 of 2
      • Lift up the orange ribbon cable in the bottom left corner of the device.
      • Peel off the small piece of gold tape underneath the orange component back.
      Ask FixBot
    3. LG Dare Earpiece Replacement: step 12, image 1 of 2 LG Dare Earpiece Replacement: step 12, image 2 of 2
      • Undo the clips that attach the black plastic strip to the frame of the phone.
      • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
      Ask FixBot
    4. LG Dare Earpiece Replacement: step 13, image 1 of 2 LG Dare Earpiece Replacement: step 13, image 2 of 2
      • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
      Ask FixBot
    5. LG Dare Earpiece Replacement: step 14, image 1 of 2 LG Dare Earpiece Replacement: step 14, image 2 of 2
      • Rotate the phone upside down with the back facing you.
      • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
      Ask FixBot
    6. LG Dare Earpiece Replacement: step 15, image 1 of 3 LG Dare Earpiece Replacement: step 15, image 2 of 3 LG Dare Earpiece Replacement: step 15, image 3 of 3
      • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
      • Do not detach the frame yet.
      Ask FixBot
    7. LG Dare Earpiece Replacement: step 16, image 1 of 3 LG Dare Earpiece Replacement: step 16, image 2 of 3 LG Dare Earpiece Replacement: step 16, image 3 of 3
      • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
      Ask FixBot
    8. LG Dare Earpiece Replacement: step 17, image 1 of 2 LG Dare Earpiece Replacement: step 17, image 2 of 2
      • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
      • Remove the frame from the plastic panel.
      • The next two steps are for earpiece removal only.
      Ask FixBot
    9. LG Dare Earpiece Replacement: step 18, image 1 of 2 LG Dare Earpiece Replacement: step 18, image 2 of 2
      • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
      • It may be necessary to apply more force to remove the pad because it is taped to the frame.
      Ask FixBot
    10. LG Dare Earpiece Replacement: step 19, image 1 of 2 LG Dare Earpiece Replacement: step 19, image 2 of 2
      • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
      Ask FixBot
To re-assemble your device, follow these instructions in reverse order.
Haoyan Huang
151 Reputation
4 Guides authored
Cal Poly, Team 9-4, Regan Winter 2012 Member of Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 34
All Time: 1,718
