Up to 20% off select tools
LG Cosmos Side Case Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,670
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 - 50 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
If you have damaged your side case, it is possible to replace. It requires time, a lot of disassembling, and includes many small parts.
    1. LG Cosmos Side Case Replacement, Battery: step 1, image 1 of 1
      • Apply an upward force to slide the back cover off.
      Ask FixBot
    2. LG Cosmos Side Case Replacement: step 2, image 1 of 1
      • Use your finger to push down on the top of the battery and pull it out.
      Ask FixBot
    1. LG Cosmos Side Case Replacement, Rear Case: step 3, image 1 of 1
      • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
      Ask FixBot
    2. LG Cosmos Side Case Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to pry the rear case loose.
      Ask FixBot
    3. LG Cosmos Side Case Replacement: step 5, image 1 of 1
      • Once the rear case is loose, lift it from the rest of the phone.
      Ask FixBot
    1. LG Cosmos Side Case Replacement, Motherboard: step 6, image 1 of 1
      • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
      Ask FixBot
    2. LG Cosmos Side Case Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to pry the motherboard loose.
      Ask FixBot
    3. LG Cosmos Side Case Replacement: step 8, image 1 of 1
      • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
      • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
      Ask FixBot
    4. LG Cosmos Side Case Replacement: step 9, image 1 of 1
      • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
      Ask FixBot
    5. LG Cosmos Side Case Replacement: step 10, image 1 of 1
      • Use your finger to pull the flex cable out from its connector.
      Ask FixBot
    6. LG Cosmos Side Case Replacement: step 11, image 1 of 1
      • Pull the motherboard away from the rest of the phone.
      Ask FixBot
    1. LG Cosmos Side Case Replacement, Silicon Keypad: step 12, image 1 of 1
      • Lift the silicon keypad away from the rest of the phone.
      Ask FixBot
    1. LG Cosmos Side Case Replacement, Side Case: step 13, image 1 of 1
      • Remove the four 2.0mm Phillips #000 screws on the golden squares.
      Ask FixBot
    2. LG Cosmos Side Case Replacement: step 14, image 1 of 1
      • Slowly lift the side case away from the rest of the phone.
      • The flex cable can be torn if it is caught on the frame of the side case.
      Ask FixBot
Author
with
Johnny Phane
91 Reputation
5 Guides authored
Cal Poly, Team 13-63, Johann Spring 2013 Member of Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,670
